wow, that`s nasty. I`ve gone through 3 yes 3 (80 spoked) rims being bent by a pot hole. 2 of them I didn't even notice till I cleaned bike and then saw it.
Yes, it's happened to me but not with those rims. On the older air strike rims.
I immediately found the busted rim on the front but when I laid down on one side to look at it closely, I happened to look over at the back wheel and found the back rim busted as well. So check....
ESP (road hazard) picked up mine. All 1600 bucks worth.
Yea when I hit it the jolt was pretty good kept the bike up and came to a light finally and my friend told me the tires flat and I knew it already I expected a cut in the tire not crack in the rim and I got the bike home slowly since I wasnt too far from home as thats where we were all headed.
You can see where the asphalt patch failed - did you report it to the City - here in Colorado if a pothole is reported and then you hit it, they are responsible for the damages
