looking for advice on....
Old Mar 9, 2015 | 06:08 PM
glide2005's Avatar
glide2005
I've done three, piece of cake. You only need to remove the outer fairing and the switch cap housing. Remove the radio also. I've always used Hill Country Custom. They have anything and configuration you want. You didn't say what size you were getting, so not sure if you need to extend wires, but that's not a problem either. It's not hard to do, just time consuming. You'll want to go slow as to not leave anything out and to make sure when your finished, everything works.
Old Mar 9, 2015 | 08:18 PM
06SGWA's Avatar
06SGWA
Originally Posted by harleynut07
Thanks guys im sure ill get it or be back for helpful hints or questions when i run into a problem thanks again
Yeah, chime in if you run into any troubles. We can help.
Old Mar 9, 2015 | 09:09 PM
harleynut07's Avatar
harleynut07
Ya thats who i ordered through was hcc i read some reviews some good some bad took the chance because it was a good price for a total kit bars and cable for under 500 my buddy has a set from them loves em and also did say they gave him wrong lenght clutch cable but he said he called and they sent 1 rite out before he even sent in the wrong 1 so that made me feel a lil better like they have good customer service well c when i do the instsll
Old Mar 10, 2015 | 06:02 AM
just plain john's Avatar
just plain john
Subscribed.
Old Mar 10, 2015 | 06:22 AM
decencyxdefied's Avatar
decencyxdefied
It's too easy to justify paying someone to do it.. Just do it, if u mess up then redo it.. It'll be a good learning experience for ya
Old Mar 10, 2015 | 06:42 AM
lp's Avatar
lp
I have literally done 20+ sets of bars. These guys will walk you through any trouble you might have but I'll only add one thing I don't see mentioned very often (because it's probably common knowledge):
Lay a heavy wool jacket or something over your gas tank in case the bars slip, master cylinder slips, or something falls out of your hand etc.
You can thank me later...
Old Mar 10, 2015 | 07:31 AM
SD lumpy's Avatar
SD lumpy
Just take your time they are plug and play
Old Mar 10, 2015 | 08:18 AM
SBates08's Avatar
SBates08
Originally Posted by lp
I have literally done 20+ sets of bars. These guys will walk you through any trouble you might have but I'll only add one thing I don't see mentioned very often (because it's probably common knowledge): Lay a heavy wool jacket or something over your gas tank in case the bars slip, master cylinder slips, or something falls out of your hand etc. You can thank me later...
Cover your fender too.
Also there is no need to go through the trouble of pulling the radio. The inner fairing will rock forward far enough to access the riser bolts.
2010 Limited with some stuff!!
Old Mar 10, 2015 | 03:20 PM
harleynut07
No i got the basic kit so gunna extend wiring and pull it through myself
Stonewall69
Sep 27, 2011 09:32 AM
DirtyThirty
Mar 5, 2011 10:37 PM
Rollie
Oct 19, 2006 09:34 PM
Trash Rat
Jun 4, 2006 09:36 AM
12Stones
General Topics/Tech Tips
11
Nov 18, 2004 03:40 PM
