damn oil filter
Old Mar 11, 2015 | 11:19 AM
  #31
leon anthony's Avatar
leon anthony
Race Face I have had to use Big *** Channel locks also
Old Mar 12, 2015 | 09:06 AM
  #32
Tucker99's Avatar
Tucker99
I replaced my stock filter mount with a chrome plated mount. The filter mounting face is also chromed and the filter spins off by hand. I think the smooth chrome surface of the mount with an oiled filter gasket makes a good seal without having to make it too tight.
Old Mar 12, 2015 | 10:07 AM
  #33
Juan-The-Human's Avatar
Juan-The-Human
Originally Posted by RaceFace
I started using the K&N filters with the nut on the end specifically for that issue. When I got my bike, that bitch seemed welded on too!! Big *** Channel Locks helped take it off. Good luck!!
I also really like the K&N CHrome Oil Filters with the nut on the end. Makes the job very easy no matter how much you tighten upon installation!
Old Mar 12, 2015 | 11:28 AM
  #34
lt1-xjs's Avatar
lt1-xjs
Originally Posted by jmn1960
mine was not steel , but plastic , from an auto parts store , but I have used it for years with no problems
You won't strip the Harley piece and it's only like $ 11.
Old Mar 12, 2015 | 12:33 PM
  #35
Leftcoaster's Avatar
Leftcoaster
It's always that last 1/4 turn that gets ya. Bet the OP won't do that again.
Old Mar 12, 2015 | 05:57 PM
  #36
porschemann's Avatar
porschemann
I do lube the seal , and that is the filter cup that stripped the 3/8 hole out of the middle
Have someone weld or braze a 1/2" nut onto that tool for you. Then you can use a 1/2" drive ratchet with a short extension and a 3/4" socket. The stamped sheet metal stuff is just Chinese junk.
Old Mar 12, 2015 | 06:03 PM
  #37
Gliden's Avatar
Gliden
Relocate it.......see where mine is by my saddle bag in the thumbnail below?
Old Mar 12, 2015 | 06:39 PM
  #38
lt1-xjs's Avatar
lt1-xjs
His was a plastic piece.
Old Mar 13, 2015 | 12:31 PM
  #39
bizarro's Avatar
bizarro
6th Gear
Hold the stuck filter in your right hand and spin the bike counter clockwise with your left. Works every time.
Old Mar 13, 2015 | 01:25 PM
  #40
Copyless's Avatar
Copyless
Exactly how would that work? Since that procedure would only tighten the filter more.
