S&S adjustable pushrods,not Quickie?
Old Mar 15, 2015 | 07:11 AM
bobbyjoes's Avatar
bobbyjoes
Default S&S adjustable pushrods,not Quickie?
Hi, if you seen my other post have a noise with new built engine,you guys with S&S adjustable non quickie,the instructions are week,so when pushrod is fully collapsed ,,then hold top into rocker arm socket while turning down the adjuster till no lash,then while holding top pushrod with wrench turn the adjuster down 4 more turns,then take the lock nut and tighten down to adjuster,is that correct,thanks
Old Mar 15, 2015 | 07:39 AM
Harleycruiser's Avatar
Harleycruiser
Yes, I have never used the s&s but procedure is same as se just different thread count.
This is the preloaded, what keeps the hydrolic lifter from ticking.
Make sure you are top dead center on the combustion stroke, so that you are off the can lobe.
Make sure to let the lifter bleed down that you can spin it with your fingers before you turn the motor over to do the other or you can bend a valve.
On the se's most guy to half an extra turn to full turn extra to get them quiet so same with the s&s.
Old Mar 15, 2015 | 07:53 AM
Harleycruiser
Just read your other thread, did you soak your lifters or pump them up while soaking in oil before install ing them,
Takes forever or what it seems like. If you have oil pressure run it for a minute.
Old Mar 15, 2015 | 08:10 AM
Harleycruiser
Bobby it looks like I am trying to help you on two different forums.
This is getting to confusing for me.
Old Mar 15, 2015 | 08:17 AM
bobbyjoes's Avatar
bobbyjoes
oh ,i am sorry ,i often post on 2 forums ,in case no response on 1,sorry
Old Mar 15, 2015 | 08:18 AM
bobbyjoes's Avatar
bobbyjoes
yes i did soak the lifter ,did you hear video,oil light come off and 32 pounds oil pressure
Old Mar 15, 2015 | 08:58 AM
Harleycruiser
NP, yes saw the video, it is not harmfully noisy, I would readjust them, and go an extra half to 3/4 of a turn and see if that helps.
HD Bobber
Engine Mechanical Topics
May 19, 2015 07:32 AM
MacKo2000
Apr 27, 2014 10:54 AM
tripacer1
Nov 28, 2010 09:58 PM
gregsdart
Nov 3, 2010 02:23 PM
cthowards
Feb 6, 2010 08:51 AM
