would you change
Old Mar 15, 2015 | 09:21 AM
fenwick's Avatar
fenwick
Default would you change
been running vied for over a year now with no issuse . the bike runs good but been looking at ordering micro from FM . so would you change something thats not broken or will the micro make my bike run even better
Old Mar 15, 2015 | 09:26 AM
SafetyMan's Avatar
SafetyMan
I would change.
Well, to be 100% honest, I would never put ied units on my bike.
Look hard at a flash tuner...
PowerVision... TTS... FuelPak3...
Old Mar 15, 2015 | 09:32 AM
badasstruck's Avatar
badasstruck
I went ahead and went all in with a pv2 when I did my stage 1. Thought long and hard about the ied product. I'm glad I got the power vision now. The map that FM sent to me with the unit was good, but being able to auto tune the bike has it running awesome!! I would upgrade...
Old Mar 15, 2015 | 09:34 AM
GTK's Avatar
GTK
If your bike runs good,why change anything unless your doing some performance engine upgrades.Vied's are good for a stage one setup only.
Old Mar 15, 2015 | 02:29 PM
fenwick's Avatar
fenwick
so im still split on to change or not
Old Mar 15, 2015 | 02:41 PM
TcHunter's Avatar
TcHunter
Im guessing here, but you must be doubting yourself if the bike is really running as good as it could.
If there is a area of concern, performance, low end torque, mid range torque, gas mileage, horsepower or what ever you feel if anything is lacking then change, if not spend your money on something else.
Old Mar 15, 2015 | 02:44 PM
mkguitar's Avatar
mkguitar
it's $ vs ?
I am a happy XIED user...I know what they do, and how the ECM works.
I have generally good results- the bang for buck quotient is very high.
It is very possible that you will get better results with another device- THAT is completely dependent on the settings used.
( i have seen plenty other bikes with "tuners" which run poorly- the entered settings are wrong)
For one though you can with most devices raise the rev limiter- if that has ever been a concern for you ( less likely with stock cams).
Only you can do the math which works for you.
generally a stage 1 will result in 7 to 10 gained horsepower, just by uncorking the input and output of the motor- more flow.
the difference between the 7 and 10 is the chosen pipes, intake and "tuner".
Mike
Old Mar 15, 2015 | 02:48 PM
Deadstroke's Avatar
Deadstroke
Get a wait till a event and get a 50 buck dyno run and look at the sheet if it looks good stay with what you have if it can be better then get it.. But buy a good tuner you are going to stay with, you dont want to get one and then regret it later..
My opinion, if it is running well, you like it and the gas mileage is good dont change..
Old Mar 15, 2015 | 03:53 PM
tccraiger's Avatar
tccraiger
I don't even know what you are talking about
Old Mar 15, 2015 | 08:40 PM
0ldhippie's Avatar
0ldhippie
Do not waste your time and/money on anything but a flash tuner. While you're at it, get a proper dyno tune...
ridedaddy
Aug 28, 2014 03:40 AM
MotoPhreke
Mar 21, 2013 04:55 PM
Newharleylover
Nov 26, 2011 07:55 PM
liverpoolfc
Exhaust System Topics
13
Mar 22, 2011 10:51 AM
squale147
Jan 20, 2009 08:54 PM
