RK started smoking!
Old Mar 16, 2015 | 11:20 AM
SIDECAR BOB's Avatar
SIDECAR BOB
I suspect it could be oil not draining back into the sump quick enough filling the rocker boxes, wondering if either the new oil pump is pumping too much oil and can't drain back from the heads quickly enough causing it to be sucked out of the breather, or oil pressure relief valve sticking causing excessive pressure and flow? would check the actual oil pressure.
Old Mar 18, 2015 | 12:51 PM
Larry the Landlord's Avatar
Larry the Landlord
Update. I pulled the air cleaner, there is oil puddles in the vents.
Likketysplit
2014-2024 Touring Models
34
Sep 30, 2016 07:26 PM
bbmfic
Nov 7, 2014 07:54 PM
Runner58
Aug 17, 2014 06:14 PM
reserve
Jun 16, 2012 01:28 PM
supercub12
Oct 12, 2011 09:28 PM
