Issues with Stainless Fasteners
Old Mar 22, 2015 | 02:38 PM
the warden's Avatar
the warden
Default Issues with Stainless Fasteners
I am about to install a polished Grade 8 stainless engine bolt kit. I know that you need to be careful about thread galling when using stainless bolts in aluminum engine parts, making the bolts difficult, or even impossible, to remove later. I will be using anti-seize or lock-tite, depending on the application, when I install the new SS fasteners and adjusting the TQ values recommended for the use of SS and anti-seize/lock-tite. For those of you who have installed polished SS fasteners, have you had any issues with thread corrosion or galling.
Old Mar 22, 2015 | 08:49 PM
Lakerat's Avatar
Lakerat
Nope, just make sure the threads are clean before installing.
Old Mar 22, 2015 | 09:25 PM
Keithhu's Avatar
Keithhu
Ok, so - primary cover, using stainless bolts - is it anti-sieze or loctite?
Old Mar 22, 2015 | 09:42 PM
trnewman's Avatar
trnewman
I used anti seize on all engine covers and haven't had any issues in over a year.
Old Mar 22, 2015 | 11:25 PM
DanDman's Avatar
DanDman
I did some research before installing SS fasteners due to what I heard about galling. I used Blue or Red Loctite with Loctite 7088 primer. Where it was needed I used anti seize with nickel.
I have had Stainless Steel fasteners on my bike for about two years now. The ones removed doing repairs have shown no signs of galling or corrosion. They look good as new.
Old Mar 23, 2015 | 07:02 AM
Spartanden's Avatar
Spartanden
it may be that the galvanic reaction between aluminum and steel may not be prevelent with stainless..... i believe that as long as the threads are clean, fasteners are not forced, things should be fine. I replae many of the factory fasteners with stainless when i can. no problems yet!
Old Mar 23, 2015 | 02:38 PM
103 sedona orange's Avatar
103 sedona orange
I used SS fasteners on my FXR back in the day & had no issues. Yes, the threads must be clean. This is a great kit for rethreading/cleaning. I'm not suggesting you purchase the kit. just showing what I use all the time in the garage. If you use a tap, get a bottom end tap.
Good luck. http://buy1.snapon.com/catalog/item....roup_ID=675360
Old Mar 23, 2015 | 03:04 PM
beary's Avatar
beary
I don't there is a risk with the SS fasteners, it's the chrome plated steel that are the issue. And I'm told it is mostly with the chrome on chrome that are at high risk.
Beary
blacktop37
Oct 16, 2019 05:21 AM
Berick
Jan 12, 2016 01:18 PM
timberwolfz28
Nov 27, 2013 07:48 PM
larazauk
Apr 7, 2008 12:49 PM
cpa55
Detailing
Jan 1, 2008 12:49 PM
