Stripped Battery Post
Old Apr 22, 2007 | 08:37 PM
Taterdog's Avatar
Taterdog
Default Stripped Battery Post
The negative terminal on my battery has stripped. The bolt still tightens somewhat, but turns at the end of travel, so it's not in there solid.
Anyone know a good fix for this? Don't think it's giving me any trouble so far, but I'm having a "cough" in the 2000 to 3000 rpm range and just wonder if this could have something to do with it.
Thanks,
Jim
Old Apr 22, 2007 | 08:56 PM
Mr Wonderful's Avatar
Mr Wonderful
Default RE: Stripped Battery Post
Hmmmmm. Assuming this is a HD battery? Might try the next larger metric or sae sized bolt. Or, maybe run a little JB Weld in the hole, wait until it is almost set, and "tap" it with the bolt. Then let it set-up overnight to harden. Used this trick on a plastic form once. If all that fails, maybe a brass insert in the battery would do it.
Old Apr 22, 2007 | 09:01 PM
Taterdog's Avatar
Taterdog
Wonderful, all good ideas. I had wondered about the JB Weld, but wasn't sure if it's conductive or not. Last thing I'd want to do is insulate the bolt!
Think I'll try upsizing the bolt first, and if that doesn't work maybe the JBW. Guess maybe a threadsert would work too, huh?
Thanks!
Old Apr 22, 2007 | 09:39 PM
pococj's Avatar
pococj
"F" drill bit, 5/16-18 tap. Done it a few times over the years.
Old Aug 29, 2020 | 04:15 AM
Larry Sellnow's Avatar
Larry Sellnow
1st Gear
Default Battery post
Thanks,
Jim
I had problems with negative post What I did was pulled out the nut from the post and converted it to dcrew in from the top instead of the side
Old Aug 29, 2020 | 05:50 AM
NorthWestern's Avatar
NorthWestern
13 year bump. This is a record.
Old Aug 29, 2020 | 08:25 AM
Screamin beagle's Avatar
Screamin beagle
Close but no cigar....while 13 years is impressive our record is currently 14 years 3 months and 17 days. Sorry to report to the resurrector there are no prizes for 5th place lol.
Old Aug 29, 2020 | 09:30 AM
GTK's Avatar
GTK
Maybe Sellnow is trying to get his post count up since he joined in 2016 with only 4 posts.
Old Aug 29, 2020 | 09:38 AM
Uncle Larry's Avatar
Uncle Larry
... is someone keeping track of "resurrection posts" ???
Old Aug 29, 2020 | 12:54 PM
ve9aa's Avatar
ve9aa
