Bike moves with clutch in
Old Mar 29, 2015 | 11:43 AM
Hogwild63's Avatar
Hogwild63
2nd Gear
Default Bike moves with clutch in
If I start my 2014 RK in gear, clutch in, the bike will jump forward. At a stop sign if left in first it wants to move forward. When put into gear it always clanks. Is this just a simple clutch adj or something more. Don't feel safe riding it.
Old Mar 29, 2015 | 11:50 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
adjustment should take care of it.
Old Mar 29, 2015 | 11:51 AM
oakmossy's Avatar
oakmossy
mine does it too. Every v twin I have ever owned has done it, yamaha 1100, kaw 1500 etc.
Old Mar 29, 2015 | 11:52 AM
RushKing14's Avatar
RushKing14
Cable and or clutch adjustment should take care of that issue. Is there some play in the lever before you feel resistance when pulling back? There should be around a 1/16th to an 1/8" space on the lever if I recall correctly.
Old Mar 29, 2015 | 11:55 AM
bigheadted's Avatar
bigheadted
a properly adjusted should take care of it. It is a simple procedure and should take only 15-20 minutes.
Old Mar 29, 2015 | 11:56 AM
103 sedona orange's Avatar
103 sedona orange
Follow HD Service Manual directions. You can also google it. Good luck.
Old Mar 29, 2015 | 12:14 PM
Norms 427's Avatar
Norms 427
Two separate issues:
1) If u start your bike with a cold engine, first start of the day, the starter will want to move the bike aggressively forward if you're in 1st gear when starting. That's normal. If u start your cold bike in neutral and then shift into 1st it's gonna CLANK. That's normal.
Even though the CHANK from the first shift of the day into 1st gear is normal, I don't like it. So I eliminate it completely by putting mine into 1st, pull in the clutch, and while sitting in the seat I push the bike back a foot or two. At first it's really hard (breaking the oil tension) to push back but after a few inches it eases up. THEN I start the bike in 1st gear and the starter motor still moves the bike forward a little bit but not much. No CLANK. Yes, it is a little more wear, perhaps, on the starter motor but I just hate that CLANK.
2) You do need to adjust your clutch since your warmed-up bike wants to creep forward. Not hard, follow the manual.
Old Mar 29, 2015 | 01:57 PM
skratch's Avatar
skratch
make sure that you adjust your clutch with the bike cold......
Old Mar 29, 2015 | 02:44 PM
chris h.'s Avatar
chris h.
Read "cold" as room temperature.
Old Mar 29, 2015 | 06:23 PM
Rustrtal's Avatar
Rustrtal
Your not going to adjust away the clunk nor the bite when you start it in gear. The lurching at a stop will go away if adjusted properly.
