Changing clutch basket, have a quick question
Old Mar 31, 2015 | 06:25 PM
DieselJoe's Avatar
DieselJoe
Default Changing clutch basket, have a quick question
Okay so I need to change my clutch basket because the ring gear is shot, does anyone know off hand what size the front and rear nut is? Need to pick up some sockets for them tomorrow...
Old Mar 31, 2015 | 06:46 PM
mkguitar's Avatar
mkguitar
not off the top of my head
more importantly check your manual- on most models the clutch nut is left hand thread
do not use air impact tools on this or on the comp sprocket bolt.
and disconnect the battery...
mike
Old Mar 31, 2015 | 07:27 PM
Am4wag's Avatar
Am4wag
Comp.sprocket nut-1 1/2",right hand threads.Cluth hub nut-1 3/16",left handed threads.
Old Mar 31, 2015 | 10:00 PM
DieselJoe's Avatar
DieselJoe
If I use anything besides a impact wouldn't the motor try to spin?
Old Mar 31, 2015 | 10:27 PM
mkguitar's Avatar
mkguitar
an impact on the comp can knock the magnets off the rotor...when you start up they destroy the stator= $$$
impact on the clutch hub can destroy the shifter dogs in the tranny= $$$$
how to lock these?
plastic tools are made which will lock your primary.
some of us use wood, a rag or hemp rope....jammed into the primary chain/sprocket.
to lock the motor, take out a spark plug, turn the motor to BDC...insert hemp rope in thru plug hole....turn motor forward it will hit the rope and jam.
all natural fibers are best- no plastic, nylon, polyester
mike
Old Mar 31, 2015 | 10:29 PM
Am4wag's Avatar
Am4wag
Block of wood to wedge between sprocket and chain.A binding aid so to speak.Anyhow,FWIW,I've used an impact on BOTH of these sprockets (and not only on my current bikes) since the need arose (late 70's) and have never had a problem doing so.
Old Apr 1, 2015 | 05:02 AM
Terryjft's Avatar
Terryjft
+1 on checking the manual!!!! The clutch hub is *right OR left* depending on what year.
Old Apr 1, 2015 | 06:15 AM
heritagecycles's Avatar
heritagecycles
1st Gear
Buy or make yourself a jam bar that works between the clutch hub and compensator. They work great to remove and install/re-torque both of the nuts.
Old Apr 1, 2015 | 06:39 AM
DieselJoe's Avatar
DieselJoe
Also could anyway provide me with the torque specs of these two nuts? Would be highly appreciated!!!
Old Apr 1, 2015 | 06:54 AM
smokindave's Avatar
smokindave
+++1 THE RIGHT WAY TO DO THIS! Don't jam anything into the primary chain, clutch hub or comp, use a JAM BAR. You can make one out of 1/4" T X 1.5" W plate.
Lastly GET A MANUAL. It will show you the right tools to use.
