Vapor lock?
If you have had any tuning done, timing advanced too far can cause what you are describing.
Weak battery or loose/corroded cables also cause this.
Starter solenoid or starter are other things to check.
Most of them are MMI grads, no?
There are 2. yes TWO "HD" mechanics I trust in this world.
Both ran their own shops for years, one in Neon, Kentucky, the other in Bethleham, PA, and both were offered enough to go to work for local HD shops.
I had to have a shift shaft replaced under warranty last week. (Yes, even with everything I've done, my warranty is intact). When they brought it back out, the first thing I did was make sure it still had oil in it.... I don't trust them.
What's worse than a HD mechanic?
In order, going down...
HD Service Writer
HD Parts guy
HD Salesman
Some of them are awesome guys, super nice to chit chat with, but I don't trust any of them for solid, honest advice.
What do you have for mods on your bike?
You should be checking your battery cable connections at both ends then use a meter to check your voltage drop at the starter.
