Halogen to LED ( fog lights question )
Old Apr 17, 2015 | 10:37 AM
SS-StreetGlide's Avatar
SS-StreetGlide
Default Halogen to LED ( fog lights question )
xxxxxxxxxxxxxxxxxxx
Old Apr 17, 2015 | 12:54 PM
bklynbob's Avatar
bklynbob
Go to the spud site and look up the part number. They often have the installation instruction sheets posted.
Old Apr 17, 2015 | 06:15 PM
sanman4ever's Avatar
sanman4ever
I changed out the halogen bulbs on my fog lamps with LED's to match my TLP7 and CD LED turn signals.
Attached Thumbnails Halogen to LED ( fog lights question )-tl-p7-high-beam.jpg
Old Apr 18, 2015 | 07:13 AM
Rustrtal's Avatar
Rustrtal
It's strange that those are labeled "Reflector" lamps since they look just like the Projector style.
Old Apr 18, 2015 | 07:25 AM
RANGER73's Avatar
RANGER73
To answer your question. The wires wont know the difference.
Old Apr 18, 2015 | 10:39 PM
Ragtop's Avatar
Ragtop
Could you please tell me where you got the replacement LED's that fit
into the stock harley fog lamps? Are they just plug and play?
Thanks!
Old Apr 19, 2015 | 06:36 AM
sanman4ever
Thanks!
Plug & play with anything that has a H3 connector. You might have to file a small bit on the bulb part to get it to fit. I think I just jammed mine in there.
Do an EBAY search, try H3 LED 26SMD. Run you about $6.00
If you want a little brighter try here: Type H3 for a search.
http://store.ijdmtoy.com/
Just so you know they're not going to throw a lot of light down the road like a halogen bulb will. I got a deal on the fog lamps and wanted them to match my current LED set up. They do help with other drivers being able to spot you.
Old Apr 19, 2015 | 07:16 AM
CarrollB's Avatar
CarrollB
I installed these passing lamp LED's. http://www.socalmotogear.com/Harley-.../hdled-50w.htm I measured the output in lumens with a $3K light meter from work comparing the stock halogen to these lamps. The output is not as bright as the halogen lamps but they match the Harley LED headlight light in color temperature, producing a white light. If I had it to do again I would still buy these. Somewhere on this forum I did a writeup with the exact measurements in lumens and color temperature.
Old Apr 19, 2015 | 07:20 AM
grbrown's Avatar
grbrown
So far I haven't found any LED H3 bulbs that will go inside my oval fogs. The stock bulbs are very small and all the LED bulbs I've found to date are relatively huge!
As for the Daymaker fogs, they are designed to fit on the vertical part of the engine guards, not the horizontal part. As bklynbob points out the fitting instructions are indeed on H-D's website, well worth reading!
Old Apr 19, 2015 | 08:05 AM
sanman4ever
Do you have the same fog lamps as me? The LED's I have fit and have some room to spare as well.
Attached Thumbnails Halogen to LED ( fog lights question )-led-foglamp-bulb.jpg
