FLHRCI sensitive steering ??
Old Apr 25, 2007 | 08:02 AM
PapaTravis's Avatar
PapaTravis
Default RE: FLHRCI sensitive steering ??
I put on 18' apes, now that is a different feel all together from stock. Seems to be a lot more top heavy, which makes tight turns very easy, actually. I was told that these kind of turns would be tough, but they were wrong in my case. As for your situation, I would go with the tire pressure first, heard you really gotta watch it with tubed tires and wire wheels. Then I would run it to the dealer to lube the bearing. Good luck, I am sure whatever it is is fixable and you will be out enjoying the sun in no time.
[IMG]local://upfiles/12433/143BB79581E245B6B0C3487DEB540B1C.jpg[/IMG]
Old Oct 25, 2021 | 10:28 AM
Kerpdog's Avatar
Kerpdog
5th Gear
Default Similar problem
I have an electric glide ultra classic, 1995. At highway speeds, if I do a gentle slalom there is a little wiggle in the handlebars as I come back out of each gentle turn. I’m wondering whether that is normal or it could have something to do with the way the bearings or fork are adjusted. Could it be an incipient death wobble?
I understand that with a bike on a lift, when you deflect the handlebars they should return to center, go slightly past and then return to center again and that there are specifications for how much swing is allowed. Any thoughts on my situation?
Old Oct 25, 2021 | 12:22 PM
Ironhandjohn's Avatar
Ironhandjohn
And a 14.5 year old thread bobs to the surface… What’s the record?
Old Oct 25, 2021 | 12:24 PM
kel03's Avatar
kel03
All new members have done it, plus old threads need love also.
Old Oct 25, 2021 | 03:44 PM
Kerpdog's Avatar
Kerpdog
5th Gear
Is this my fifteen seconds of fame!?!? At last!
Old Oct 25, 2021 | 04:10 PM
MURPHCC1's Avatar
MURPHCC1
5 seconds, no one cares........
Old Oct 25, 2021 | 04:35 PM
nomoreyellowfootprints's Avatar
It is a valid question and one which I experienced just this week. I adjusted the air pressure and it made little, if any difference. I like the bearing lube though.
Old Oct 26, 2021 | 12:41 PM
Ironhandjohn
Replacing the rear tire with a new one cured my RK of the issue. The old one had an edge worn in that made the bike squirm when leaned onto it.
Old Oct 27, 2021 | 07:10 AM
Kerpdog's Avatar
Kerpdog
5th Gear
Default Squirm
Actually, I do feel a little of that. “Squirm” is the exact word for it. I’ll check for that issue.
newmanb138
2014-2024 Touring Models
47
Jul 11, 2016 05:09 PM
LCCXL1200X
Jun 19, 2013 12:23 PM
Cheech2010FLHTK
Mar 20, 2011 08:20 PM
mfortkamp
Jan 9, 2011 05:37 PM
oley55
Jul 26, 2010 07:57 PM
