FLHX Brake Light Issue
Old Apr 27, 2015 | 08:34 PM
cmass's Avatar
cmass
Default FLHX Brake Light Issue
Hey everybody,
Just came across an issue on my 2011 FLHX. My buddy noticed that the left brake light only comes on when braking or turning; otherwise, it is no illuminated (see picture).
Any ideas where the issue lies? The brake assembly was just replaced end of last year after getting t-boned.
Thanks in advance!
Old Apr 27, 2015 | 08:41 PM
Buelligan666's Avatar
Buelligan666
Try a new bulb.
Old Apr 27, 2015 | 08:45 PM
TSheff's Avatar
TSheff
I'm assuming you mean running light - brake light should ONLY come on when braking. If it lights when leaning sound like a contact issue - bulb, wiring connection, ground, or broken wire.
Old Apr 27, 2015 | 08:51 PM
103 sedona orange's Avatar
103 sedona orange
I had a similar issue. The turn signal would work sometimes. The bulb was not making contact. Replaced the bulb & problem solved.
Old Apr 27, 2015 | 09:14 PM
cmass's Avatar
cmass
Yes, the running light. I'll try replacing the bulb. Thanks for the input!
Old Apr 27, 2015 | 09:48 PM
RollaMo's Avatar
RollaMo
It has a duel filament bulb, so it is entirely possible that one of the filaments is burned out.
That would explain why it works as a brake/turn signal light, but not running light.
Old Apr 27, 2015 | 11:13 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Be sure to put just a little dab of die-electric grease on and around the end of the bulb for good measure.
Matt Freund
Electrical/Lighting/Alarm
Mar 1, 2019 01:43 PM
K.Harland_17
Mar 28, 2013 07:26 AM
haligonian
Aug 26, 2012 01:19 PM
gonzo3426
Aug 17, 2012 08:42 AM
aped06classic
Mar 15, 2008 11:44 AM
