Stupid Question...Tire Tread Depth
Old May 8, 2015 | 01:42 PM
scottbess's Avatar
scottbess
Default Stupid Question...Tire Tread Depth
I'm sure some of the seasoned riders here can answer my question about tire tread depth. I've got about 9k miles on my tires, both with about 3-4/32s of tread depth. From what the dealer told me at my 10k service (yes, I know that taking it to the dealer for my 10k service is my first problem), I should consider replacing my tires sometime soon.
I have a 700 mile ride coming up soon. Should I be concerned and buy new tires now or am I needlessly worrying about it and I have plenty of tread left?
I don't know what the tread depth is on a new tire, so I don't have anything to compare it to.
Thanks for any input you might have!
Old May 8, 2015 | 01:45 PM
SafetyMan's Avatar
SafetyMan
If you have 3/32, you should be good for 700 miles.
I have a depth gauge, so I keep a close eye on mine.
Old May 8, 2015 | 01:46 PM
Joe12RK's Avatar
Joe12RK
the tires have wear indicators just like car tires - they'll tell you how low you can go. FWIW most people get 12-15k out of their tires, but not all do.
Old May 8, 2015 | 01:48 PM
grbrown's Avatar
grbrown
You can check new tread depths by looking at the website for your brand of tyre. Front tyres are typically around 5mm or 3/16", rears around 7-8mm or 3/8". I would say your tyres are fine, although obviously I can't see them!
Old May 8, 2015 | 01:58 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Depends a bit on the conditions.
Dry pavement, you can go bald and be fine.
Rain, you're more likely to hydroplane. That becomes unpleasantly exciting very quickly when it happens. The less the tread the more likely the hydroplaning.
Dirt & gravel. Just a generic loss of traction, which makes the turns more exciting and has the bike floating and drifting more.
Personally, I'd replace the tire now, before the trip. I'd also do it well before departing, so if any problems with the mounting or balance of the tires shows up it can be dealt with before hitting the road.
Old May 8, 2015 | 01:59 PM
FinalShot's Avatar
FinalShot
If you have between 3 &4/32, you should be good to go for your ride. I generally take mine down to 2/32 which I think is where the wear indicator shows up as flush. In Texas, I think 3/32 is the minimum limit to pass state inspection.
Old May 8, 2015 | 02:08 PM
ynots's Avatar
ynots
1/8 inch should be good for 700 miles. Ive nearly ran my last 2 rear tires down to smooth. My main concern on thin tires is rain
Old May 8, 2015 | 02:31 PM
KCFLHRC's Avatar
KCFLHRC
The only issue with bald tires is the rain. They are great on dry pavement.
Old May 8, 2015 | 02:48 PM
st john's Avatar
st john
This statement applys to Dunlop 402 tires only! there are two specs to go by. 1. Harley says to replace at 2/32 and 2. Dunlop says to replace at 1/32. I go by the 1/32 and this puts me at about 15k on the rear and 30k on the front. For some that is about 1 tire change per year for me it is a tire change about every 3 years.
Old May 8, 2015 | 02:53 PM
y2kflhr's Avatar
y2kflhr
a new rear has about 8-32nds if I remember correctly, that last 3-4 will take a bit to go through you should be fine for your trip but replace when you come back. Personally I would replace it now and be done with it
