To LED or not to LED
Old May 18, 2015 | 02:21 PM
FireFighter200's Avatar
FireFighter200
Default To LED or not to LED
So how many of you out there installed LED accent lighting? If so, did you buy a kit or piece it together?
I have been on the fence about doing a kit from Custom Dynamics. I am looking to add more noticeability during night time riding but I don’t want to make the bike look to trashy. I had a kit from Custom Dynamics on my old Yamaha and it worked great with no problems. Any ideas would be appreciated.
PJ
2014 Amber Whisky SGS
Old May 18, 2015 | 02:33 PM
Roadie13's Avatar
Roadie13
All my lights except the headlight are upgraded to LED for the extra visibility, but too afraid of the trash factor like you mentioned to add accent lighting. I think some small well placed ones would help, but don't care for the Vegas style light shows some guys go with. To each his own, I just don't care for the over the top stuff.
Old May 18, 2015 | 02:43 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
2014 SGS: This weekend I installed the F & R LEDs from CD. I went with the Dynamic Rings in front & standard LEDs in the rear. I will eventually add a LED headlight once I find what I like. Im not into the multi LEDs are over the bike... just not my style.
I do think the LEDs add a measure of safety
Old May 18, 2015 | 03:01 PM
batman.'s Avatar
batman.
I added the CD turn signals front and back and went with the Cirus LED headlight. For 75 bucks for both bulbs you cant go wrong. All plug and play on the 14's As far as the light show LEDS I may invest in a few down the road but for now it was about the safety factor not the check me out at the shows factor
Batman
Old May 18, 2015 | 03:06 PM
fwb35's Avatar
fwb35
I did all LED lighting on my 99 for safety, much better at night, while I was at a bike week event I had a LED orange engine light kit put on, since then I have added to it, I have bought strips from other places but have found Custom Dynamics to have the best stuff.
Old May 18, 2015 | 04:17 PM
AnotherBlackSG's Avatar
AnotherBlackSG
I think most here missed the point. I believe OP is asking about accent lighting.
When I first got my SG, I mounted led accent lighting around the motor (a couple of sets of Lizard LED's - link below). 6 or 8 different colors & patterns available, etc. but the novelty wore off real quick for me. Less than a year later I pulled 'em all off. I just felt kinda hokey, I guess, but to each his own. For what it's worth, Custom Dynamics is a great company to deal with.
https://www.lizardleds.com/motorcycl...ight-kits.html
Old May 18, 2015 | 06:36 PM
just plain john's Avatar
just plain john
I have CD accent lighting, lots of it. I believe they improve my visibility at night. To me, some of the accent lighting I've seen looks too pimp. I don't care for the strobe/breathing or changing colors. I chose a single color (red, like my running lights) and they don't strobe or change intensity. I have them under the tour pack, under the bags, below the battery box, the horn, the air cleaner, both frame rails under the engine, under both sides of the tank, under either side of the front fender, and behind the speaker grills which I made from a mesh trash can. I installed them carefully so that they are not directly visible, although the under bag lights reflect off the mufflers when parked on the kickstand. Looks great to me and you can see me coming from a mile away. Operated by a remote key fob.
Old May 19, 2015 | 05:30 AM
94ruck's Avatar
94ruck
I bought the walmart stuff as a joke, put on red above the motor and blue underneath. it actually turned out reall good, took an hour to install and it is still on, guess the joke was on me!
Old May 19, 2015 | 05:41 AM
just plain john
I'd be concerned of the legalities of red and blue lights in combination.
Old May 19, 2015 | 09:19 AM
King-a-ling's Avatar
King-a-ling
I did same as 94ruck, except I got the ones from Autozone. Did red over the motor and ran em off the aux. switch. I like mine, they don't change colors and they're bright and I may have $30-40 invested in them. I've had them for about two years and they still work perfectly. And true, they aren't legal in La. and probably most states.
