2015 sg
Old May 19, 2015 | 05:30 PM
gamb's Avatar
gamb
Default 2015 sg
question : will stage 1 air filter and x pipe with stock mufflers need a tuner adjustment?? can i run stage 1 air filter , x head pipe, and stock mufflers WITHOUT retuning?? thanks
Old May 19, 2015 | 06:17 PM
SafetyMan's Avatar
SafetyMan
Short answer: No.
You just spent over 20 grand on a motorcycle...
Now you want to spend another $1500ish on pipes, intake, etc, and you don't want to tune the engine for those changes?
Long answer:
If I've posted it once, I bet I've posted it 43 times...
The FIRST thing a man should do when considering making changes is GET A TUNER. It will help a stock bike, and when you change pipes and or air cleaner, you're ready for it.
Can you run without a tuner? Yes.
Will you blow your engine up running without a tuner? Probably not.
Can you expect to get 50,000 miles out of your engine without a tuner? Most likely.
Will it run correctly without a tuner? No.
Dealers and their parts and service departments are a business, in business to sell motorcycles, and motorcycle parts and accessories. They tell you that you can get away without a tuner, because a LOT of guys won't come off the jack for a tuner, and they're afraid they'll lose sales if they tell you to get a tuner.
Changing the air flow without changing the VE tables is not beneficial. These bikes run lean from the factory, adding a more free flowing exhaust makes them run more lean.
Do what you want, I won't criticize, just trying to offer things to think about.
...but there is a reason I won't buy a used bike as my primary ride...
Old May 19, 2015 | 06:43 PM
houstonhdguy's Avatar
houstonhdguy
I think it's closer to 44 times... But you are right.
Old May 19, 2015 | 06:54 PM
rbaley680's Avatar
rbaley680
Agree. Runs stronger, cooler, smoother. I bought the FP3 before AC and pipes and it really makes a difference. I think I've read it 43 times, and it's great advice.
Old May 19, 2015 | 07:43 PM
gamb's Avatar
gamb
Default 2015 sg
i'll say it once! getting better than 55 mpg on last 4 fill ups!! never had this GOOD on any bike or trike with or without a tuner! and yes i have a power vision for it ,but i did not want to change anything that would ruin my mpg.
Old May 19, 2015 | 08:14 PM
SafetyMan's Avatar
SafetyMan
Think about how lean you are running to get that mileage.
Lean=hot.
Is that good for the internals???
I'm not saying you will... but IF you burn a hole in a piston, do you think that could be attributed to the parts you put on?
Hopefully you save enough by not buying a tuner and that gas mileage to build an engine.
Again, I am not criticizing, just stating my worthless opinion.
And restating why I don't buy used bikes as my primary rides....
kryingame
May 22, 2015 10:33 PM
dcrittenden
Apr 17, 2015 07:30 AM
41inWV
2014-2024 Touring Models
Mar 21, 2015 12:31 PM
roadkinglobo
22
Mar 20, 2015 08:48 AM
ducatidesmo
Feb 21, 2015 12:42 PM
