Power Vision users
Old May 21, 2015 | 09:42 PM
digger58's Avatar
digger58
The loaded tune was not great, not bad just not great, ran it through a couple more, no popping or backfires now but I did not push hard on either. Tomorrow it will get a workout on hills, through residential and city traffic, on the way home I will open it up on the hi way and re flash it when I get home. At that point I will bet things will be pretty close and will only fine tune the parameter tabs.
Old May 21, 2015 | 10:15 PM
jt metal's Avatar
jt metal
Yeah.....mines going to get a work out as well. Hope it works out.....Lol!
Old May 21, 2015 | 11:00 PM
mgmmgm's Avatar
mgmmgm
I ran a few tune runs with the map FM sent me for 2-1 V&H pipe, had some ping, so sent the map and data log to Jamie at FM, and he sent me a revision of the map- wow! Totally Awesome. Bike runs great.
Old May 22, 2015 | 12:37 AM
del P's Avatar
del P
Stage III
I've had this tuner for about a year now. I'm about to go to something else because the rear cylinder runs way too hot. I've been trying all the different tunes for true duals with big sucker and the rear head pipe is glowing red way too quickly. Plus I also go into parade mode really quick if I hit slight traffic.
Old May 22, 2015 | 08:50 AM
WVDevil's Avatar
WVDevil
Got to ride today for the first time since tune. Definitely better. Will probably try AT this weekend to tweak it a bit more.
Old May 22, 2015 | 09:03 AM
0ldhippie's Avatar
0ldhippie
You don't need a different tuning device, you need someone who can properly tune your bike on a dyno.
Old May 22, 2015 | 09:33 AM
WVDevil's Avatar
WVDevil
^ Agree.
Old May 22, 2015 | 10:02 AM
gipper's Avatar
gipper
You've been trying "all the different tunes"? With ALL due respect, you don't articulate your position in such a way so as to make it sound like you've mastered AT.
I won't claim to have mastered it; technology isn't really in my wheelhouse. In fact, much of what the PV can do is WAY above my head and area of interest. That being said, I was having the exact same problem that you were, and a 45 minute run in AT in the areas where my bike was going into parade mode fixed the problem.....completely. My bike hasn't gone into parade mode since.
My bike was overheating and going into parade mode in stop and go traffic (even in the dead of winter), which is not where I had run any of my AT's prior to that. All of my AT's had been run on open road where I do most of my riding. Well, that was (as I found out) leaving out the very critical area where most heat builds up. It's important to run AT in all the areas where one will ride, and it does take some time and patience. I have found that it's worth the effort though.
I wouldn't claim that the AT is the perfect substitute over a good tune on a Dyno. It may be, and it may not be. I don't know enough to make the claim either way. I can confidently say though, that the PV with all of its capabilities is an adequate substitute for 90% of us, and that's pretty darn good. Be patient and play with it if you haven't done so.
Old May 22, 2015 | 01:59 PM
jt metal's Avatar
jt metal
my initial reaction after 40 miles is this. Still running on canned tune. in the back of my head. Adding 5 horsepower to a thousand pound machine, I kept expectations low, as one should.
the bike is smoother, somewhat stronger, and apparently is getting 44mpg on the p.v. Gage. So expectations have been met.
Will work with auto tune tomorrow. And see if it does anything.
I did a tuner for future upgrades. So no regrets! Lol!
Old May 22, 2015 | 02:13 PM
WVDevil's Avatar
WVDevil
Headed out now to do autotune
