corvette shocks fail
Old May 29, 2015 | 08:23 AM
slammed05fatty's Avatar
slammed05fatty
its bad enough ppl read internet to gather info on topics their not familiar with, but taking a craigslist ad as the gospel that a completely new low LMAO
to each their own, that is why they are options. but don't knock something till you try it first hand
Old May 29, 2015 | 08:33 AM
EasTexUltra12's Avatar
EasTexUltra12
Originally Posted by twistedcherokee
On any air shock, when lifted above stock ride height, the shock no longer just controls up & down. As for side load, don't think for one minute that a car won't produce side load in a turn. As for using them on a Harley, I am one of those people. The stock shocks on our FLTH's are a air shock. The Vette shocks have more travel & has more pressure capabilities. There are companies out the that do use the same shock, some have some minor differences, just as brand to brand will do. Arrnott comes to mind & charges 800.00 more for the kit. Cost for the DIY is 200.00+-50.00 depending on how you do your dump valve & air compressor. People have been doing this for years, this is not a new find. As for failing due to the eyelet breaking off, prove that was even on the bike when it broke, or not used on something else before it broke. Prove that it wasn't tampered with or a setup to have people stop doing it because someone doesn't think it is right. Good luck
Toby
Thanks for the explanation.
David
Old May 29, 2015 | 10:54 AM
bagman1's Avatar
bagman1
Toby
Keep one very important thing in mind. The side load in a auto chassis is minimal which any movement is absorbed by the rubber bushing and kept in a position by suspension parts, like theyre designed to do, and if they break you can still get from point A to point B. Putting them on a bike now they are the major connection link to the rear of the bike, when they break its good night.
Some things are made to be modified, some are not. I don't think this is one of them. But to each their own.
Old May 29, 2015 | 11:39 AM
bigheadted's Avatar
bigheadted
I took nothing as gospel and was simply sharing something I saw as I know a lot of folks use these shocks.
Pull your wadded panties out now.hahahha
Old May 29, 2015 | 11:45 AM
slammed05fatty
my post was not directed toward you. it was more for ones in the poo slinging after your post LMAO. all good here panties perfectly comfortable... wait i forgot them... damnit again
Old May 29, 2015 | 12:19 PM
bigheadted's Avatar
bigheadted
I got too fat for panties now !! Talk about a chapped crack !! Ewwww.
Old May 29, 2015 | 12:29 PM
BigMike's Avatar
BigMike
With all of the shocks on the market that are specifically designed for a Harley touring bike, what is the point of installing a car shocks design for a 2 ton vehicle?
Old May 29, 2015 | 12:43 PM
bigheadted's Avatar
bigheadted
One reason is to look cool by "slammin" the bike to the ground when parked.
Another is I hear the bike rides really nice and with a small compressor, some switched and a dump valve they are on the fly adjustable.
Also there are a few small mods to make regarding the shock eyes and bushings?? Plus as stated welding or beefing the existing welds up some.
Old May 29, 2015 | 05:23 PM
BigMike's Avatar
BigMike
Legend Suspension
Progressive Suspension
Tricky Air & Billet
Platinum Air Suspension
Arnott
Old May 29, 2015 | 07:42 PM
Johnny Wolf's Avatar
Johnny Wolf
Originally Posted by uriel
Good thing I welded mine on both ends. So if you do this mod, definately dont try to save a few bucks by not getting them welded.
Yup me too. In addition many don't space them properly so the nut and washers are tight up against the shock mounts. This doesn't allow for any pivot, so they bind and break.
I've seen it many times on line, they go on forums like this and say what a shi*y system it is, and they can't believe they installed those crappy cheap shocks... etc.. etc.
