Low voltage
Old Jun 1, 2015 | 07:09 PM
sanman4ever's Avatar
sanman4ever
Originally Posted by green hd
Many thanks for the inputs, guys! Hopefully tonight I will get a chance to do a final diagnosis. If it is the stator, has anyone replaced one on an Ultra? If so, any surprises in store for me, or any tricks to make it easier?
You'll have to remove the compensator. There's a thread here on how to perform that. You need a big *** torque wrench as well. I just replaced my stator with an upgraded Cycle electric one.
Old Jun 1, 2015 | 07:56 PM
green hd's Avatar
green hd
Yeah, I saw that on a youtube vid. You got a Cycle Electric stator? I see that brand out there and was wondering if they were any good.
Old Jun 1, 2015 | 08:08 PM
sanman4ever
Yes Cycle Electric. Top quality. I got mine from Dennis Kirk. Several on EBAY as well. Stator install is easy. Just time consuming getting to it.
Odds are it's your battery or regulator. Do the tests mentioned in the electrical forum "sticky's"
Old Jun 1, 2015 | 09:24 PM
green hd's Avatar
green hd
Stator's toast. 0.3 ohms to ground on each pin. only putting out 7.5 volts at 1000 rpm's and 15 at 2500 rpm's. guess will order my new then. Thanks for the help.
Old Jun 2, 2015 | 10:49 AM
slammed05fatty's Avatar
slammed05fatty
I just went through this. Mine was charging high and low then worked fine for a week and then i was dead on the side of the road and had to get tow home... Regulator was my issue, changed it and charged battery up and all is well now. Thankful it wasnt my stator
Old Jun 7, 2015 | 08:20 PM
green hd's Avatar
green hd
Bad stator. Replaced it and back on the road. Thank god I had a service manual. Saved about $300. Also decided to try just regular 10w40 in the primary. 2 stators burnt up with fancy syn oil in there. See how long this one lasts.
Old Jun 7, 2015 | 08:47 PM
lp's Avatar
lp
Even though your stator was toast, make sure you do the Regulator checks.
You can actually have one side of the regulator working fine, looks like it's charging like normal, everything looks fine but the other side of the regulator is shorting a stator phase to ground. It ends up cooking the stator... again...
Doing the same stator job twice for a friend because of a wacky regulator.
96RK
Dec 18, 2011 06:24 PM
dunderwood
Jul 30, 2011 09:54 PM
hellboyrich
Mar 6, 2011 11:52 AM
timberwolfz28
EVO
Jun 25, 2009 09:05 PM
twinsdaddyo
Dec 22, 2004 03:43 PM
