Overheating question
Old Apr 28, 2007 | 02:42 AM
Mr5150's Avatar
Mr5150
Default Overheating question
At what temp point is considered overheating? What point is oh crap there's a hole in my motah? Probably 90 sumpn here today, lotta stop and go. Even splitting traffic was still hot, thousands of cars stopped for ten or 15 miles creates a lot of heat, not much chance to cool her off.
Old Apr 28, 2007 | 05:43 AM
hogdoc's Avatar
hogdoc
Default RE: Overheating question
260 head temp is "operating temp" oil temp should stay under 250
Old Apr 28, 2007 | 06:04 AM
talon1674's Avatar
talon1674
When she over heats you'll know it. The motor goes into a super rich condition and the motor makes a loping cycle sound, it revs up and then back down almost like its gonna die on you. had it happen in Vaegs to me in 2005!
Old Apr 28, 2007 | 10:02 AM
glide's Avatar
glide
Like said above 250 and below for oil temps is where you should be ideally. Synthetics will protect you to about 300 but if you reach that point, some sort of fuel enrichment or even an oil cooler should be considered if you operate in a hot climate.
Old Apr 28, 2007 | 10:17 AM
FLHDRIVER's Avatar
FLHDRIVER
If all else fails the ECMshould shut the motor down. There could still be residual damage from running hot over a prolonged period of time, but the newer bikes electronics help in preventing catastrophic melt downs.
Old Apr 28, 2007 | 02:49 PM
Mr5150's Avatar
Mr5150
OK thanks for the replies.. It sounds from what your all saying is that oil temp is what I should be looking at. I've got the Thundermax ECM which allows you to look at head temp peaks that have been logged into ECM memory. Yesterday it hit 312 a couple of times. Before that the highest it got was 304. But I have no idea about oil temp. Are those digital dipsticks worthwhile or just one more thing to break? Thanks.
Old Apr 29, 2007 | 02:04 AM
soos's Avatar
soos
Digital dipsticks are OK but you have to be stopped in order to read them. You are much better off with a dash oil temperature gauge. Dipsticks are easily stolen too.
Old Apr 29, 2007 | 10:39 AM
StreetGlide2006's Avatar
StreetGlide2006
ORIGINAL: soos
I agree with whatsoos said above. But just for reference, I started with the dipstick and because I wanted to know the temp while riding I replaced the useless air temp gage with an oil temp gage. Both gages run with in 5 degrees of each other at any given temp so the dip stick is a good choice if that is the way you decide to go. I prefer the dash gage but use the dip stick to keep an eye on oil level easily.
Ride Safe,
Mike
kylebryan
Oct 16, 2023 04:28 PM
steelerdude1
May 29, 2023 12:53 PM
harleydude68
Jul 28, 2009 10:28 AM
Beercan321
May 26, 2008 11:52 AM
Varooom
Mar 28, 2006 11:48 AM
