clutch lever effort after installing apes
Old Jun 20, 2015 | 06:04 AM
SG-Jay's Avatar
SG-Jay
Thanks Wideglide. Does your motion pro cable match the brake line? I used sterling chromite cable and lines and want the two to match obviously. I'm going to call Magnum on Mon. This cable is only 2 months old.
Old Jun 20, 2015 | 06:21 AM
Wideglide103's Avatar
Wideglide103
I switched to stainless when I bought the motion pro. The magnum I had was not stainless.
As far as the magnum cable, probably just got a bad one. Hopefully they will take care of you. I didn't even try, so can't comment on customer service.
Old Jun 20, 2015 | 06:34 PM
SG-Jay's Avatar
SG-Jay
Thanks Wideglide. I'm going to call them on Monday. Now that you mention it, it didn't fall through the sheathing before I installed it.
Old Jun 20, 2015 | 06:54 PM
TSheff's Avatar
TSheff
Sounds like your going to possibly change it. Pull the cable - (catch the fluid in a clean pan) - and inspect the cable to see if it has debris or any visible problem. Lube the crap out of it while it's off. Can't hurt and if it frees up put it back on and ride - If Not, it's already off.
Old Jun 20, 2015 | 09:21 PM
SG-Jay's Avatar
SG-Jay
I decided to try and lube it, and it worked! I took it off at the bar end and sprayed cable lube in it, put it back on and it's like a different cable. So much for not needing to lube the Magnum cables.
Old Jun 20, 2015 | 10:58 PM
Bagger_Vance's Avatar
Bagger_Vance
Has anyone else had an increase in clutch lever effort after installing apes? I have 12' Yaffe's and a magnum shielding cable. I noticed more effort required after the install, and the cable is routed the same way it was stock.
I expected a little more effort but mine is a lot. We had a long ride in a severe rain storm and the next day it was even stiffer.
I did the exact same set up (braided Magnum) and yes it was much stiffer until I lubed it even though it was new. I have a heavier clutch spring so it was magnified even more.
Old Jun 21, 2015 | 07:03 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Originally Posted by TSheff
Lube the cable well and re-route it outside the frame with only a big looping curve, just to check. If it's easy like that you need to route it where it is not in a bind. If it's not easier I'd say you got screwed on a cable.
What he said.......Did that with my 12" Twin Peeks and between the better cable and routing, it's easier and smoother then stock...
Keith4001r
May 23, 2021 06:03 PM
Justinalesi
Aug 17, 2017 09:10 PM
03 Fatboy
Jan 30, 2017 09:46 AM
Mental
Aug 4, 2013 01:01 PM
scottystreetbob
Apr 14, 2012 10:08 PM
