Brake Light Turn Signal conversion pigtail
Old Jun 22, 2015 | 04:58 PM
prezflyr's Avatar
prezflyr
Default Brake Light Turn Signal conversion pigtail
I have a 2009 Ultra Classic and would like more back lights. I purchased a conversion pigtail from a guy that had it on a 2011 Ultra Classic. It is not working very well and really doing strange things. When I push a blinker switch, that side blinks bright but the other side blinks very dim and both dash arrows blink as they do when my emergency flashers are used. The running lights and brake lights do not show up on the turn signals as they should. Since I am running without my tour pack, does anyone think that may be the problem since that light connector is disconnected? Any suggestions since it works well on his Ultra Classic with his tour pack on.
Old Jun 22, 2015 | 05:11 PM
davidwruth's Avatar
davidwruth
I would start with checking the ground in the pigtail u bought. If u can take it off and re test to see if it is in the bike or the pigtail would b something else I would check early
Old Jun 22, 2015 | 11:16 PM
hellbilly78's Avatar
hellbilly78
Also if you used dilectric grease that stuff can do some really goofy ****. I had trouble with my rear led lights staying lit up for brake but after some tests and cleanin that junk out its been fine.
Old Jun 23, 2015 | 12:16 AM
mkguitar's Avatar
mkguitar
I use the HD run turn brake module on my 2009 flhtc ( your T/P on or off will not contribute to this).
The Hd module works perfectly- I got mine for 1/2 on the classifieds.
What "pigtail" did you get?
it sounds as if a diode is bad in it
Mike
Old Jun 23, 2015 | 07:04 AM
1flhtk4me's Avatar
1flhtk4me
I just went thru this with mine.
There are different harnesses....like 4 wire,5 wire types.
I bought a hitch that came with a harness.
I ended up buying a new 5 wire for my trailer.
It had to have separate blinkers,brake and tail lights.
The one that did not work was checking out like yours.
Old Jun 23, 2015 | 07:38 AM
prezflyr's Avatar
prezflyr
I did put on some dilectric grease before installation so I will clean it up and try again. There are no part numbers on this pigtail but the guy I got it from said he had it on an 2011 Ultra and it worked fine. I have a 2009 Ultra and it does not work .
Old Jun 23, 2015 | 09:23 AM
14GuineaPig's Avatar
14GuineaPig
Maybe this will help.
http://www.harley-davidson.com/store...caps-_-PDP+Top
Stampy167
EVO
16
Jul 17, 2015 12:22 PM
ringonking
May 22, 2013 04:29 PM
tourglider
"The Florida Crew"
Apr 2, 2012 05:30 PM
RodFarmer
Aug 9, 2009 06:52 PM
lmb1485
Apr 12, 2008 10:02 PM
