Setting tire bead
Old Jun 27, 2015 | 06:37 PM
speednut's Avatar
speednut
^^^ That is what you need.
Old Jun 27, 2015 | 07:18 PM
voodoodrug's Avatar
voodoodrug
had same problem,did the same things,even a shop was scratching there heads, it was a long time ago, I put a inner tube in it problem solved.
(there is an old wise tail that it could over heat though)
Old Jun 27, 2015 | 07:49 PM
nevets61's Avatar
nevets61
starter or brake cleaner spray will do the trick, like others said, not too much, just a spray into the tire, butane lighter to the rim and woosh, it'll pop the bead on asap, so keep fingers clear. once on pull valve core and air it up and down a couple times good to go.
Old Jun 27, 2015 | 08:55 PM
t100rc's Avatar
t100rc
I've encountered a few that were particularly difficult to bead. Is one side beading and then just not riding all the the any up the other side, or is it just not holding enough air to get the bead to want to set at all?
In the first case, lube it good, put the air to it and give it time ... A mallet whack sometimes helps, too (you have already ... I read it!)
In the second case, cut a length of garden hose to exactly the diameter of the rim bead and stuff it between the tire and bead on one side (lube it well!) and put the air to it ... The other side will bead .... Then, start removing the hose (watch your fingers!) and the bead will set as it push s the hose out ... Or, drop the air once one side beads, remove hose and put the air back ... Pushing the tire toward the non-beaded side will help ...
Years ago, we always used starting fluid and a match to set tires on big truck split rims ... I never successfully beaded a motorcycle tire that way ... I also never seriously risked burning down the motorcycle shop ... :-\
Old Jun 28, 2015 | 07:39 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Nothing to it. Dude here still uses too much.
Then they ride, the naysayers stand around and moan.
Old Jun 28, 2015 | 09:33 AM
sixguns's Avatar
sixguns
never mind, you already tried the ratchet strap
Old Jun 28, 2015 | 09:40 AM
Florida Swamp Yankee's Avatar
I'm going to try the garden hose trick, both sides are seating about 3/4 of the way, the last 1/4 won't stretch over. I tried starter fluid this morning, and noticed the can I have is only 50% ether. Should this be done with the stem out? I couldn't get it to "pop", just burn on the outside like there wasn't enough oxygen inside the tire for it to combust.
What is the proper Fuel air ratio? Am I running too rich? WTF?
Old Jun 28, 2015 | 09:47 AM
OwnerOfHarriet's Avatar
OwnerOfHarriet
blow air from the opposite side of the tire -- a lot of car tire machines do that.
Old Jun 28, 2015 | 09:52 AM
Finally!
In this case, the stem needed to be out to allow combustion air in.
I sprayed some near the stem and with the residue from previous attempts, it popped on and it's tighter than a bulls bunghole in fly season!!
Thanks for all the replies, and always keep a can of starting fluid on the shelf!
Old Jun 28, 2015 | 02:33 PM
timbo141's Avatar
timbo141
Use a tube. I know it's a tubeless tire... but will work.
I see that you got it sealed.
Now enjoy the ride.
