Is this Normal?
Old Jun 28, 2015 | 05:55 AM
Notgrownup's Avatar
Notgrownup
After riding in the rain for about 6 hours my switches acted weird once on a trip, came back to normal once it dried.
Old Jun 28, 2015 | 09:06 AM
hvacgaspiping's Avatar
hvacgaspiping
Memo from HD service department, "They all do that"......
Old Jun 28, 2015 | 09:16 AM
ndnguyd's Avatar
ndnguyd
Put some good electrical grease in your connections/plugs. Keeps water out plus helps with corrosion.
Old Jun 28, 2015 | 09:33 AM
acd118's Avatar
acd118
+1 on water being the enemy. Problem for this OP is that the water might be affecting another electrical connection that isn't even being discussed right now. I'd have it checked out if the issue persists.
Old Jun 28, 2015 | 09:52 AM
cass's Avatar
cass
, yeah pretty much. i've been through some pretty hard storms. if you're gonna ride any amount, you're gonna get caught in one eventually. you can either wait under a bridge someplace or embrace it, put on your wet weather gear and get going again. I've been pretty lucky in that i haven't had any problems...knock wood....i try and make sure the fairing is seated best it can be and that the seal on the windshield is positioned and tightened up. other than that not more you can do. i like the grease idea. might add a little extra protection at the connectors.
Old Jun 28, 2015 | 11:57 AM
SafetyMan's Avatar
SafetyMan
Dielectric grease is your friend.
When I'm working on mine, any connectors I see gets some.
HyperM3
Sep 29, 2014 01:59 PM
jackinthebox
Jan 26, 2014 07:30 PM
flhal05
Nov 16, 2009 07:56 AM
maineultraclassic
Jun 3, 2008 07:19 PM
donald_5d
Apr 25, 2008 10:25 PM
