new tires= wobble
Old Jul 15, 2015 | 08:28 PM
ZenGlide's Avatar
ZenGlide
Wow... deja vu.
I have experienced this same thing and came to the conclusion it was somehow related to new tires. Not long after I bought my new 2012 FLHTCU, I experienced this same wobble/instability consistently at about 70-75 mph. It wasn't bad enough to make me lose control, but it did make me nervous enough to stay below that speed. After a few hundred miles, it seemed to settle down and go away. I never did find out what caused it and I eventually forgot about it.
At about 4K miles, I removed my stock wheels and tires and replaced them with new take-off Street Glide wheels and tires because I thought they looked better than the original wheels. To my surprise, the wobble returned at almost the exact same speed. And again, it lasted a few hundred miles and eventually went away. I have no idea what was causing this instability, but it definitely seemed to be related to brand new OEM tires.
Old Jul 16, 2015 | 04:36 AM
stic2it's Avatar
stic2it
Originally Posted by arkmark
Traditional weights, I'll try the higher air tonight. I usually run 35 front 38 rear
That is probably low, if u go on the manufacturer website they usually recommend a tire pressure for the size and model you have. Avons gave me some trouble, they were damn near unrideable. I am riding 40 front, 44 rear. The tire dealer did not know the right pressure
Old Aug 6, 2015 | 04:36 PM
RidemyEVO's Avatar
RidemyEVO
I just went through this on my 2002 dyna and even installed a true track system and had wobble at 140 - 160 kph. An old time mechanic told m to use the air pressure thats on the frame sticker and not the pressure embedded in tire. I was running 40 and 40 and sticker said front 30 and rear 40 and I adjusted and wouldnt you know it no more wobble.
Old Aug 6, 2015 | 05:19 PM
jaxdwg's Avatar
jaxdwg
Originally Posted by foxtrapper
I suspect the tires are not fully seated on their beads when you get it, and work the beads down/in the rest of the way during those first few hundred miles.
I have tendency to agree with you. I use a Teflon spray on the bead area when I inflate and over inflate to get the bead totally seated. If the bead is not totally seated, the tire will (my term) Hump, until it does fully seat. And with 119k on just this bike and having changed all my own tires, I've changed a bunch of tires.
Old Aug 7, 2015 | 03:21 AM
grbrown's Avatar
grbrown
Red face
The cause of the problem is very simple - new tyres need to be run for a couple of hundred miles, to remove that new moulded surface they all have. Nothing more than that! My brother had new tyres fitted on his bike a few years ago and rode back home as he always did, on the ragged edge, and slid off the road on the first fast bend - twit! He hadn't gone more than a few miles.
When using non-stock tyres always check that brand's website for the correct pressures, as some use different pressures to the owners manual, Avons (my favourites) especially. DO NOT go by the frame sticker, unless those numbers are recommended by your chosen brand!
Old Aug 7, 2015 | 04:40 AM
fishbust's Avatar
fishbust
Exactly why I would never go 75 mph with brand new tires. I ready about this a long time ago, the new tires need to wear in and they are even slippery on road surfaces right "out of the box".
A quick google found a similar article along the lines of tire break in...
http://motorbikewriter.com/break-new...orcycle-tyres/
Old Aug 7, 2015 | 04:48 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Aye, new tires tend to be slick, but that's not the same as a rhythmic wobbling.
Old Aug 7, 2015 | 10:05 AM
RidemyEVO's Avatar
RidemyEVO
Thanks Graham I will keep this in mind. On the Avon website http://www.avonmoto.com/tech/tire-pressure-guidelines for the following tires
Avon AV72 Cobra Rear Tire 150/80B16 77V
Avon AV71 Cobra Front Tire 100/90-19 57H
for my 2002 Dyna Superglide the sticker on frame shows rear 40 lbs front 30 lbs
I would be going by Sport/Sport Touring ( radial & bias ) of front 34-36 lbs and rear 38-40 lbs correct? Solo rider.
Graham what was your experience with these Avon Cobras on your dresser with the air pressures?
Old Aug 7, 2015 | 11:27 AM
grbrown's Avatar
grbrown
Thumbs up
Avon also make a 150/80B16 77H, which may have a more hard wearing compound and more tread depth. That's the size I would chose for my Glide. Being British old chap they also have lots of useful stuff on their UK website which shows 36F/40R for your bike, with those tyres you list.
I've only recently had a Cobra installed and haven't ridden on it yet. However I have used the previous Venoms for much of the time I've owned my Glide, using 130/90, 140/90 and 150/80 on the rear, over the years. I've used the recommended pressures when solo, 38F/44R, raising them to 42/50 when fully loaded for those Continental tours, when we're close to max weight for the bike.
I've tried other brands, but always gone back to my old favourite. They are compliant, give a good smooth ride, while giving excellent grip in all conditions, especially heavy rain. We've crossed Europe, as far afield as Croatia in old Yugoslavia, and ridden through all the countries in between, from bloomin' freezing to 'it ain't half hot'!
I'm looking forward to riding on my Cobra, just as soon as I get my current 'upgrades' done!
Old Aug 7, 2015 | 12:41 PM
dyna rider's Avatar
dyna rider
Default Release Agent
It's most likely the release agent they use on the mold before they put the rubber in for the tire. Without the agent they would have to dig out the tire from the mold. I had a set of Michelins on my Dyna and they skated all over the road for about 6 heat cycles and then they were fine.
ga_dirtz
Apr 1, 2017 11:16 PM
Terrabella
Jul 11, 2012 07:42 AM
ultra5516
Apr 8, 2012 09:45 AM
DavidStiebel
Mar 30, 2011 03:29 PM
Wolfx
Nov 7, 2005 09:57 PM
