Power Vision users
Old Jul 21, 2015 | 09:56 PM
gipper's Avatar
gipper
Originally Posted by Cliff R
I really think 3 good runs over a known MAP is sufficient. As mentioned earlier, with the narrow band 02's, I only try to tune the "normal" driving range, or about 30 percent or less throttle angle and no more than about 3000-3200rpm's.
It's cool to watch the auto-tune MAP while you do this, and with each additional tuning session you get fewer and fewer changes by the PV.
Tuning in this manner can pay big benefits for fuel consumption, throttle response and smoothness right off idle and thru the lower rpm/light load range. My bike went from around 36-39mpg's with the PC-5 at it's best, to 41-44mpgs with the PV after I auto-tuned and accepted the changes. That's HUGE increase in fuel economy. The only negative was that I was never overly impressed or truly happy with the power from the 2012 103ci engine, even after all the changes/upgrades and custom tuning I did to it.
Maybe I'm a bit pickier than most when it comes to these things, but I still think the base 103ci engine, at least thru 2012 is a complete "turd", and it doesn't really shine even after you throw a lot of bolt on mods to it. It really needs better cams AND all the other stuff we typically do to these engines.....IMHO.....Cliff
Very good post, Cliff, and I agree. I am not yet having my cake and eating it too, but I'm inching my way in that direction.
Old Jul 21, 2015 | 10:58 PM
jt metal's Avatar
jt metal
Thanks guys appreciate the dialogue!!! At the end of the day, want to do the best of my ability and use the PV to get me there. Also like to cruise and get 42+ when called upon!
Infancy stages on this whole PV thing. Will continue to log a few time watching for the % changes. May tinker further when I get bored......
Pretty sure if we are looking to max a givin bike out, probably be best using Auto tune pro. 14.6 to 1 doesn't sound like a recipe for big power.....lol!
Old Jul 21, 2015 | 11:05 PM
skratch's Avatar
skratch
Originally Posted by jt metal
Forgive me guys, last one?
Base map from fuel moto done!
Auto tune session done!
If the PV only makes necessary adjustments. Why would I not save it to the first auto tune session. Why have three separate saves? Doesnt make sense?
the reason that you would do that is so that if you need to 'step' back one, you can do that. if you've overwritten it, then you have to reload your base map and start all over. nothing says that once you're done, you have to keep all those interim maps, but until you're satisfied, it's a good idea to be able to make minor step backs.
Old Jul 22, 2015 | 07:06 AM
Cliff R's Avatar
Cliff R
" I also respectfully differ in that the 103 is no more a turd than the 88.....stock. They're both turds in a stock state."
Keep in mind when I mention the 103 is a "turd", I'm only talking about 2012-2013's, until they put the better cams in them.
I was told by Fuel Moto, both of our local dealerships who dyno tune, and our local resident expert who owns a dyno that the cams are "brick wall" for the 103's, and they all have dyno numbers to prove it.
I don't need a dyno, after all the money I threw at the 2012 103ci engine, it still felt "flat" for power, and not very impressive anyplace. My next step was going to be better cams, but someone made me an offer on the bike I couldn't refuse.
On the same subject, we are seeing BIG power numbers from the 2014-up 103's by simply adding 2 into 1 pipes and custom tuning.
I totally agree about saving MAPS. You should keep the original MAP supplied with the tuner, and at least one that you've "tweaked" on that produced good results. Build on that second MAP by saving the changes, then build on those MAPS, leaving the original and at least one successful MAP intact to revert back to, if/as needed.......Cliff
Old Jul 22, 2015 | 09:01 AM
gipper's Avatar
gipper
Absolutely agree that my 2012 103" was a turd...after I opened it up with a proper header, slipons, a/c, and fuel management system. It was in fact better completely stock, as I remember. However, cams changed everything, and I did that so long ago I don't even remember most of the time how dissatisfied I was prior to doing that. Interestingly enough, my attention has been on how dissatisfied I have been with the slipons I've had for the last three years, which I recently replaced with what has proven to be better performers for my set up.
Back to the PV tuning component....really informative information from you, Cliff. I may reach out to you in the future to discuss more in depth tuning tweaks on the PV.
Old Jul 22, 2015 | 09:07 AM
Bumpandrun's Avatar
Bumpandrun
Good stuff. Thank you....
Old Jul 22, 2015 | 09:37 AM
Cliff R's Avatar
Cliff R
No problem, we don't mind helping out with these things. I do it for a living, more automotive and diesel stuff than HD's, but never charge unless we get dirty!......Cliff
Old Jul 22, 2015 | 10:26 AM
jt metal's Avatar
jt metal
Great thread guys. Appreciate, so much! But what I don't appreciate is both of you guys calling out the "12 103 a turd. Kinda taking it personally. Didn't sleep much last night. Might have something to do with you guys.......
Maybe we can shift the focus back to the topic, on proper use of the PV? Hahaha. Jk!
Old Jul 22, 2015 | 11:03 AM
gipper's Avatar
gipper
"The Truth" has brought many sleepless nights for me as well!
Old Jul 22, 2015 | 11:09 AM
Cliff R's Avatar
Cliff R
HD must have known there was an "issue" with the early 103's, or at least that they were lacking a bit, or they wouldn't have opted to put better cams in them in 2014.
Nuff said about all that, but what we do know is, that you can get the early 103's well into the 40mpg range with a few bolts ons and custom tuning. Well worth the effort, and at least when you ride with your buds you can get over 160 miles on the clock before you're looking for a gas station......Cliff
