Checking to see if anyone knows about passing light problems,check fuse and pulled light of front and found no current to light.any help would be great...thanks..mike
If you have power to your headlight you should have power to the passing lamps, it's tied into the low beam wire. I suppose it's possible the wire broke. If the lights were there from the factory (Heritage) you would see the connection under the left side of the tank, if it's an after the fact add-on, it's probably spliced in inside the headlight housing.
ummmm.....your high beams aren't on, are they?<don't ask>
hey I felt kinda dumb asking about the switch, but yours was going to be next question...been an electrician for 15 years...doesn't take long to learn that the simple questions are the ones you ask first right? LOL
Kind of reminds of "slingblade" when the dudes tiller won't run and Carl opens the tank and says "it ain't got no gas in it"
