Windshield Screw's strped
Old Jul 25, 2015 | 09:26 PM
HDRetired's Avatar
HDRetired
Question Windshield Screw's strped
Has anyone had to fix the three windshield screws? I was changing out the windshield for a Klockworks shield. The fittings that go into the plastic on the inner fairing were stripped and the screw just turned. Harley told me its very common and to use an Epoxy. They are going to see if its covered under ESP but i'm going to try the Epoxy first because i have a lot of riding to do. Thanks all. Sorry no Pictures i'll try to get some .
Old Jul 25, 2015 | 09:32 PM
dawg's Avatar
dawg
Could always buy the replacement inserts, easy peasy
Old Jul 25, 2015 | 10:13 PM
soos's Avatar
soos
https://www.hdforums.com/forum/touri...+insert+repair
Old Jul 25, 2015 | 10:52 PM
HDRetired's Avatar
HDRetired
Default Windshield Screw's strped
It's. Not the inside that's stripped. It's the part that going into the inner faring that is broke and won't grip the brass any longer so it just turns and screw will not tighten
Old Jul 26, 2015 | 12:42 AM
stro1965's Avatar
stro1965
The replacement part mentioned above completely replaces that factory brass piece. I'm surprised the dealer didn't sell you one.
Old Jul 26, 2015 | 01:22 AM
sn95bullitt's Avatar
sn95bullitt
I think he's saying the plastic that holds the brass fittings is broken. I had that on my Electra glide also. I tried epoxy and it held for a few months then the plastic gave away again from all the vibrations. I ended up drilling all the way trough the inner faring hang putting bolts with acorn nuts. I have a t-bag for my windshield so the bolt heads are hidden behind the bag. Chrome acorn nuts gave the front a nice look. I've since replaced the whole inner faring.
Old Jul 26, 2015 | 05:54 AM
Jerry1834's Avatar
Jerry1834
Nice repair job!
Old Jul 26, 2015 | 06:03 AM
hogcowboy's Avatar
hogcowboy
That's exactly what I had to do as well. Unfortunately the two surfaces from the outer fairing and inner are different enough that it left a small gap on top of the inner fairing. It isn't terrible but I notice it. I have an 07 so no flat spot as you have.
Old Jul 26, 2015 | 07:41 AM
tpcowfish's Avatar
tpcowfish
I thought the replacement's from HD fixed that problem also ? not %100 sure , been a while, but i think they do
Old Jul 26, 2015 | 07:50 AM
just plain john's Avatar
just plain john
The stock insert is pressed in, but the replacement insert is threaded and is much more resistant to pulling out. As long as the insert mounts aren't broken the new inserts will solve your problem. Repairing the inner fairing is kind of hit and miss. Good luck.
