RE: How to get chrome cleaner off flat black motor parts
My bike has the siver motor, but my last bike 03 RK had the black motor. i had gotten wax on the block before. i used a toothbrush with water on it and scrubbed it off. i dont know if that would work but you can give it a try
I had the same problem youv'e described. Only after several soap and water scrubings has the marking left by the chrome cleaner started to fade. I tried various cleaners to no avail. I don't want to go at it with anything too harsh for fear of permenently marring the engine paint. Since it happened I've been using "Never Dull wadding polish" to clean the chrome with no ill effect on the engine paint.
Thanks for the info. I used to paint houses and the idea about alcohol makes sense cuz I used denatured alcohol to clean Oops from metal work or roofing metals. I guess I will try the other chrome polish, but Mothers is so good!
There is a product in an aerosol can called Pig Spit. Just spray it on the black wrinkle paint and the white is gone. If you get it on the chrome, just wipe it off with a clean rag
ORIGINAL: Carmela1
I MAY JUST BUY THAT CAUSE I LIKE THE NAME[8D][8D][8D]
ORIGINAL: Carmela1
I just got hooked into buying a can of that stuff the other day, $15.00!!! The Jury is still out till I see what it does in the long run, but it sure does make the Crink look good! No doubt!
