Drivers Backrest - Adjustable or Fixed
Old May 1, 2007 | 07:34 PM
Rocket Jockey's Avatar
Rocket Jockey
Default Drivers Backrest - Adjustable or Fixed
I am thinking about adding an HD backrest to my RG for longer trips. Just wondering about others preference to the adjustable versus fixed. It seems like it would be a set-it-and-forget-it kind of thing but I don't ride with one so...????
Thanks,
RJ
Old May 1, 2007 | 07:39 PM
alexcue's Avatar
alexcue
Default RE: Drivers Backrest - Adjustable or Fixed
I haven't tried a non-adjustable, but one thing i notice with my adjustable is it makes mounting a lot easier since it folds down when i want to sit on the bike. You are right tho it is set it and forget it, 'cause i haven't moved it since i adjusted it to my preference. ( I assume the "fixed" doesn't fold down btw).
I highly recommend it also, as it helps my posture, and keeps the lower back pain away quite a bit.
Old May 1, 2007 | 08:26 PM
jmbear328's Avatar
jmbear328
Well I got the non adjustable and you can adjust the angle with an allen wrench at the rear and it has 3 different height adjustments. I take mine on and off alot so it worked out good because I dont have to deal with the cable and adjuster when I remove it, and its gonna be just as comfy as the adjustable one once you get it where you like it at.
John
Old May 1, 2007 | 08:36 PM
Law Dawg's Avatar
Law Dawg
From: Rep of Maryland (currently serving in Afghanistan)
I have an adjustable "when I use it" when I am riding solo for a distance I'll use the backrest but when momma's onboard can't, instead I use her as a backrest.
Old May 1, 2007 | 08:39 PM
lenrough's Avatar
lenrough
Adjustable! If ya get a little tweak in your back, you don't have to pull over, bust out the tool bag - uh or take it to the dealer if you're not mechanically inclined - and make adjustments. Just pull on the little lever (you gotta take your hand off the throttle) and the puppy moves right in to position. Itsa beautiful thing.
Old May 1, 2007 | 08:56 PM
Dalton's Avatar
Dalton
Adjustable, and the wife loves it, says she feels more secure (locked in place) with it on.
I made a cable modification so I did not have to have the cable and adjuster showing under the seat fron, used a heavy duty tie strap to the adjuster lever, then looped it and riveted the loop so it is hidden in the seat opening. Not wuite as easy to adjust while riding, but very easy to adjust off the bike.
Old May 1, 2007 | 09:46 PM
wldbill's Avatar
wldbill
Did a 350 mile "Lunch Ride" yesterday and adjusted my backrest at least 3 times on the fly. It's the only way to go. Did the the install myself and the cabling wasn't any big deal.
Old May 1, 2007 | 10:29 PM
Fast Eddie's Avatar
Fast Eddie
Adjustable. You canadjustit while riding and keep the comfort factor up.
[IMG]local://upfiles/21029/C2519B775AFE4B129F81068F1A329429.jpg[/IMG]
Old May 2, 2007 | 01:13 AM
voodoodrug's Avatar
voodoodrug
Got the adj one just cause felt like it wasnt that much more $. Was not realy shure if I would use the adj. well 4 months and 4k and I am glad I went for it thow, not like jump up and down glad just seems to feel I made the right choice as of today.
Old May 2, 2007 | 01:28 AM
serverpimp's Avatar
serverpimp
I have the adjustable and love it. It slides out easy when I have the better half on the bike. One downside on the adjustable. The 'adjuster' and the heat guards are incompatible in some if not all cases. The heat guards cover over the adjuster. The newheat guards from HD plainly state they won't work with the adjustable seat. If you don't have an 07 then you probably haven't even considered the heat guards.
