Danged traffic lights
I don't have that problem. I stop directly over the cut in the road where the wire is burried.
If the light cycles and ignores me - I run the light when the traffic is clear.
When a vehicle pulls over the field a slight change is noticed in the field because of the shape change induced by the presence of Iron in the field. This inturn shows a different impedeance to the sensor in the electronics operating the "loop".
The sensitivity of this change can be regulated by a potentiometer coil(POT) located on the board forthe electronics of the circuit.
When you locate a light that is not noticing you, you should call the Public Works Department for that locality(city or town), or State DOT(Highway, State Routes), as it is thier responsibility for the intersection control devices. Once reported most will reset the sensitivity and the problem goes away.
Flashing your lights will not cause an induction loop to "fire", and that myth comes from cities where they use "IF Freq." sensors mountedat the light to "free track" emergancy vehicles equipped with a IF emitter.
One thingI have always done for years is to stay to either side of lane center in an intersection that is loop protected as the loops are normally 4 foot wide and cenetered on the lane. this will place more mass directly over the loop.
One thing I have noticed with newer instalations of loops lately is that they are now putting in pairs, with the side of each pair in the middle of the lane.
Heres a link to a real simplified explanaiton of induction loops and redlights.
http://auto.howstuffworks.com/question234.htm
Rob2002
Save your money
I put the magnet to the test this morning per instructions (Oh yea, the manufacturer guarantees it works)
Failed with flying colors
Should have bought a twelve pack
US Rider
Rob,
Doesn't a 12 pack mess with your ground clearance - one way or another?
