Stranger stuff..
Old Aug 14, 2015 | 12:23 PM
mouser58's Avatar
mouser58
Default Stranger stuff..
I was driving up Rt 19 in W.Va. Hit a hole in the asphault, not real deep, but edge was pretty square.. Bottomed out HARD!!! 5 miles down the road, my check engine light comes on.. 2 more miles, the Volt gauge is pegged, cruise does not work and 6th gear light does not work.. I stopped in the next town to eat lunch.. Called closest HD shop..told them I wanted to stop in and have it checked. he asked if I bought it there or was just passing thru.. Told him headed home.. said he MIGHT have time to check a fuse.. Came out from eating, voltage back to normal, 6th gear light works again, but no cruise..Stopped and got gas, and when I fired it up everything was working...Like I said.. Strange...
Old Aug 14, 2015 | 12:37 PM
mkguitar's Avatar
mkguitar
with any computer, shutting down and re-starting is often the cure for anomalies.
I'd set the bike in the driveway and smack the tires with a ball-bat...see if I can re-create the problem
go through and check cable connections for tightness, battery cables, ecm connector and other cables you can reach
and go from there
mike
Old Aug 14, 2015 | 05:06 PM
GTK's Avatar
GTK
and go from there
mike
Better put a helmet on so that bat doesn't rebound and hit you in the head.
Old Aug 14, 2015 | 06:49 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Old Aug 14, 2015 | 08:27 PM
mikeman54's Avatar
mikeman54
I'd like to have that Gremlin oldenuf2nobtr
Old Aug 14, 2015 | 08:51 PM
lp's Avatar
lp
Too late....
Brandon Jackson
General Topics/Tech Tips
Jun 11, 2019 09:56 AM
Yogie
Jul 23, 2016 06:52 AM
ord sgt
Jul 19, 2011 04:52 PM
MidnitEvil
Oct 9, 2009 07:53 PM
EdwardK
May 27, 2009 08:05 PM
