sloppy shift linkage
Old Aug 14, 2015 | 07:05 PM
glidein wide's Avatar
glidein wide
Default sloppy shift linkage
2014 street glide has loose linkage at the toe heel, bolts are tight, common problem ??
Old Aug 14, 2015 | 07:19 PM
SR90's Avatar
SR90
The shaft going through the primary is hardened steel, the shift levels are relatively soft and the splines do wear out. My toe shifter stripped coming home from Sturgis, luckily I had a spare in the form of a heal shifter. All you can do us make sure the new levers go on clean and tight and with loctight.
Old Aug 15, 2015 | 08:30 AM
1flhtk4me's Avatar
1flhtk4me
If the shift levers remain loose for a while,the splines will wear out.
Remove the old one(s)and and check the splines.
Also check the splines on the shaft.
Old Aug 15, 2015 | 12:05 PM
tpcowfish's Avatar
tpcowfish
I would take it to the dealer, have heard of this a few times, Buddy had this on his 15 RG, tried to tighten the bolt's, got worse, took it to a dealer on one of our rides, they were cool, and fixed for him. I think they were some put on wrong at the factory
Old Aug 16, 2015 | 06:29 PM
glidein wide
Thanks guys, we will get this straightened out at ocean state harley......
Old Aug 17, 2015 | 06:41 AM
sanman4ever's Avatar
sanman4ever
Did you upgrade Kevin?
Old Aug 18, 2015 | 08:43 PM
glidein wide
Hey Don, if I bought that, I would not consider that an upgrade !!! I'm an evo man !!LOL !!!asking about this to fix Paul's (Chico's) bike, I did get it tighter but back to the stealer it goes. We should ride soon !!
cwsharp
Aug 22, 2022 11:54 PM
kq2dc7
Jun 14, 2015 06:38 PM
DGRF250
2014-2024 Touring Models
15
Apr 28, 2014 11:58 AM
jeremy2854
Jul 28, 2013 07:21 PM
cfave
Jul 26, 2013 07:48 PM
