Heal Toe shifter keeps falling off linkage
Old Jul 26, 2013 | 05:14 PM
cfave's Avatar
cfave
Default Heal Toe shifter keeps falling off linkage
I have an 11 FLHTK and the heal toe shifter keeps coming apart where the splined shaft connects to the linkage. It fell of the othe day and I loosened the bolt and put it back on, tight. and it did it again only 3 rides later.
Any suggestions on what could be causing this and how I can get it to stop. Im going on a LONG trip and dont need this to happen when Im 500 miles from home!
Old Jul 26, 2013 | 05:27 PM
dawg's Avatar
dawg
Cut a strip from a beer can, wrap it around the shaft and use a rubber mallet to reinstall the shift lever. Or, replace the shaft and/or lever(s)
Old Jul 26, 2013 | 05:31 PM
mkguitar's Avatar
mkguitar
you may have a set of worn teeth, against worn teeth.
I would suggest that you take off both shifters, put the "heel" where the toe was a and vice versa.
snug up tight
mike
Old Jul 26, 2013 | 05:59 PM
cfave's Avatar
cfave
Sorry no it is on the other side of the shaft where the shaft and the linkage meet up. the teeth are fine it just seems to come off completely
Old Jul 26, 2013 | 06:47 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Warranty could be the answer do you have one?
Old Jul 26, 2013 | 06:49 PM
cfave's Avatar
cfave
its up!
Old Jul 26, 2013 | 06:53 PM
Harleycruiser's Avatar
Harleycruiser
Are you using locktite?
Old Jul 26, 2013 | 06:58 PM
Billfishin2's Avatar
Billfishin2
Good stuff!
Old Jul 26, 2013 | 07:01 PM
btsom's Avatar
btsom
It has been too long since I had mine apart, isn't there a narrow spot on the shaft that the bolt goes past and as long as the bolt is there, the lever shouldn't fall off? I would think some blue loktite and the proper torque would eliminate the repeat problem....unless something else is wrong. Is the allen socket head stripped so the proper torque can't be applied?
Old Jul 26, 2013 | 07:02 PM
cfave's Avatar
cfave
Yes but it doesnt seem like the bolt is coming loose it is like it is slipping off the end. the spline has a grove in it that keeps the bolt riding down the middle. seems to be popping out of it
