seat bolt spinning
Old Aug 17, 2015 | 04:48 PM
mikeo33y's Avatar
mikeo33y
Default seat bolt spinning
any body have there seat bolt just spin trying to unscrew it. can pliers or something get at it from under the rear fender. thx in advance
Old Aug 17, 2015 | 05:12 PM
bigheadted's Avatar
bigheadted
You can try using a little upward force on the seat and maybe it will allow you to remove the screw?? A little lube ??
If this works you can feed a wire through the hole and fix the new nut to the wire and pull it up then snap the clip on.
If you cannot remove the seat screw then you might be able to get to it without removing the tire but you will have to lift it up and maybe even remove the shocks to allow more room.
Good luck man.
Old Aug 17, 2015 | 05:28 PM
mikeo33y's Avatar
mikeo33y
thx. appreciate the info. ill give it a whirl
Old Aug 17, 2015 | 06:08 PM
Tracker56's Avatar
Tracker56
I have a set of really long reach angled needle nose pliers that let me reach up under the fender while sitting on the ground. They're Craftsman but I imagine you can get them just about anywhere. That's what I use to install seat bolt backing nut and clip.
Old Aug 17, 2015 | 06:50 PM
skypilot_one's Avatar
skypilot_one
Hopefully the stamped detent isn't stripped out in the fender. if it is you'll be messing with this every time you remove the seat. Might need some JB weld under the fender to hold the nut in place.
Old Aug 17, 2015 | 07:39 PM
Chief21's Avatar
Chief21
Same thing happened to me. There is an "E" clip that holds the plastic nut in place in the fender. Hold some upward pressure and turn it till the tab in the nut lines up with the notch in the fender. You should be able to get it out holding the pressure while you loosen the screw. Down side is when you get it out, the nut will fall out. I used some mechanics wire to fish it back up so I could put a new clip on.
Old Aug 17, 2015 | 08:45 PM
mikeo33y's Avatar
mikeo33y
had to drop the swingarm after pulling lower shock bolts off. got vise grips on nut. got it off. clip broke. no biggie but was a pain to get off. time for a lock washer. no locktite on that bolt ever again. thx again for the info guys
Old Aug 18, 2015 | 10:59 AM
Joe12RK's Avatar
Joe12RK
yes that screw doesn't need locktite, just a star washer - never had one fall off
Old Aug 19, 2015 | 04:12 PM
skypilot_one
I had someone ruin the detent in the fender itself. I'm gonna install an aluminum rivnut if I can.
Old Aug 19, 2015 | 07:46 PM
14GuineaPig's Avatar
14GuineaPig
I used a 1/4 - 20 well nut that fit snugly into the hole in the fender. I wasn't able to use the factory nut because the hole in the fender was deformed and enlarged. It doesn't require much torque to tighten the seat bolt. It's been working for years now without a problem. A cheap & easy repair. I think I picked up the well nut from Home Depot.
