Anybody install the Tri-Bar Lighted Rear Fender Extension Kit?
Old May 2, 2007 | 11:57 AM
05Fatty's Avatar
05Fatty
Default Anybody install the Tri-Bar Lighted Rear Fender Extension Kit?
Has anyone installed this on an EG yet? I'm most curious about the wiring of the light and if it is a plug-n-play with the factory light.[/align] [/align][/align][/align]
[IMG]local://upfiles/5783/BE37B2E209B04DCDBCE9785CBB69FCD9.jpg[/IMG]
Old May 2, 2007 | 01:04 PM
05Fatty's Avatar
05Fatty
Default RE: Anybody install the Tri-Bar Lighted Rear Fender Extension Kit?
Added Pic
Old May 2, 2007 | 07:37 PM
dansflhti's Avatar
dansflhti
I think i'll wait untilit comes out in color match.......fire red pearl.
Old May 2, 2007 | 08:22 PM
Harleypingman's Avatar
Harleypingman
I had my dealer parts guy print out the instructions. It's pretty simple. In a nutshell, the fender tip lamp is removed. Then the chrome/rubber bumper is removed. A replacement bracket for the saddlebag to rear fender support is installed; the LED goes into the extension and the extension is mounted to the fender using the two bolts that used to attach the fender tip lamp assembly to the fender, and the bottom of the extension has a bolt that attaches to the replacement bracket. The lighting is a plug and play into the tail lamp sockets.
If you look at your bike, pop the lense off the fender tip lamp and you will see the two bolts that secure it to the fender.
Reach under the fender and you will feel the bolt that holds the bracket to the fender which extends out each side to the left and right saddlebag support rails--it has two T-40 Torx screws. That is removed and replaced with the same bracket used on the RK Custom, RG, and Street Glide. HTH.
But no, I haven't installed it; I have the FLHX fender/facia on my '04 EG. HTH
Old May 2, 2007 | 11:06 PM
arelli's Avatar
arelli
looks good but the chrome piece is plastic. first time you back it up to the curb and scrape it or crack it"s all over
Gwaxley
2014-2024 Touring Models
Apr 24, 2015 04:42 PM
mattVA
Nov 8, 2012 06:37 AM
dschock
Sep 22, 2012 08:09 AM
Titan56
Aug 12, 2012 07:19 AM
bpav16
Aug 3, 2011 09:10 PM
