rear fender bracket stud
Old Aug 3, 2011 | 08:01 PM
bpav16's Avatar
bpav16
Default rear fender bracket stud
09 flhrc...the bracket inside the rear fender that attaches to the muffler/saddlebag bracket...there is a threaded stud inside the fender and a nut holds the bracket in place...mine snapped off and I'm wondering if anyone knows the repair...there looks to be a flat piece inder the decorative fender tip that the stud is a part of...thanks
Old Aug 3, 2011 | 08:56 PM
mkguitar's Avatar
mkguitar
looking at parts manual:
http://partsfinder.onlinemicrofiche....=13&A=549&B=47
you can see #32 the bracket, I think what you are calling a stud is the machine screw that comes through from the backside #3
that help?
Mike
Old Aug 3, 2011 | 09:06 PM
sh4325's Avatar
sh4325
I just orederd a new OEM rear fender. That stud appears to be welded on the fender. There is a plastic round cover that goes over it so it doesn't look to bad. My have to grind the stud out and if you can grind it out without ****** up the fender you can use a 1/4" bolt washer and nut. Good luck to you.
Old Aug 3, 2011 | 09:10 PM
bpav16's Avatar
bpav16
thats what I'm thinking...drill it out and use a 1/4-20 nyloc...the fender tip covers it on the classic....I figured it must be welded in there............thanks
Bootsie
Jul 24, 2018 03:29 PM
FFZHD
May 11, 2014 08:19 PM
BearHawg
Feb 22, 2013 09:33 PM
mattVA
Nov 8, 2012 06:37 AM
Kbore
Dec 11, 2009 12:08 AM
