Hydraulic clutch conversion on 2012 Ultra
Old Aug 19, 2015 | 08:41 PM
2012_Ultra's Avatar
2012_Ultra
Stage IV
Post Hydraulic clutch conversion on 2012 Ultra
First, I'd like to thank you all for the stuff I have learned on this site. So I thought I'd return the favor with a complete listing of what it took to install the hydraulic clutch on my bike. I did it because my new bars caused my clutch cable to cut into the ferrule, making it hard to pull in the clutch.
Bars:
Clutch Master Cylinder PN 36700056B list $335, discount $277 - eBay $58 for me.
Stock length hydraulic line PN 37200024 list $152.50, discount $126.50 - eBay $20
Crush washer (2) PN 41751-06A list $1.50
Clutch switch PN 71699-07 list $27, discount $22.50 - this is necessary because the hydraulic clutch lever is mechanically opposite of the cable clutch lever. Stock, the clutch switch is only engaged when the lever is pulled in. The hydraulic lever engages the switch all the time, except when it's pulled in. According to a post on here, the cruise won't work, the security light stays lit, and the 6th gear indicator won't work if you don't swap this switch.
Clutch side:
non-adjustable assembly PN 37000111 list $43, discount $36 - you have to remove one snap ring to remove the adjustable part of the cable clutch, the new part adds a bearing to the assembly, and removes the ability to adjust it.
You may want to replace your Derby cover gasket, but I didn't.
I also left the cover off until it was bled, so I could see the >.080" of travel on my dial indicator.
Transmission side:
Gasket PN 36805-06 list $5.50, discount $4.50 (may reuse)
Slave cylinder PN 37200023 list $163.5, discount $136 - comes with o-ring and bleeder screw. Need three PN 4705 screws $1.50 to bolt the slave to the new plate. I also used a Russell 639540 Speed Bleeder to make it really easy to bleed.
Inner plate PN 25700178 list $56, discount $46.50
Outer cover PN 25700179 list $91.50, discount $76 - I was able to reuse all six screws from the OEM setup.
Clutch rod PN 37000113 list $5.50, discount $4.50 - you pull the oil slinger assy, and slide this in. I put gear oil on it first, then the inner plate/slave cylinder slides right in place.
Overall pretty easy job. The savings on the first two items made it about half price for me. I also bought a master cylinder rebuild kit PN 37200096A list $75 to incorporate the changes with recall 0165 in April 2015.
Please ask questions, and I'll try to answer.
Old Aug 27, 2015 | 07:36 AM
ssgunny's Avatar
ssgunny
Nice and thanks for the comprehensive list. This is something I have been contemplating on doing to my 2009 FLHTCU. Hope it works well for you and if I do this I might ask you a few questions in the process.
John
Old Aug 29, 2015 | 08:36 AM
2012_Ultra's Avatar
2012_Ultra
Stage IV
Thanks! I am impressed with the feel of the hydraulic clutch, and got used to it right away. The Rushmores also got a heavier clutch spring, so mine may be a little easier than theirs to pull. I also installed an Alto Carbonite clutch a few months ago, so hopefully I'm done messing around for a really long time.
Old Aug 29, 2015 | 07:23 PM
ssgunny's Avatar
ssgunny
I guess due to your total number of posts you can't receive PM's. I sent you the following as a visitor message at your profile. In looking up the first item you listed "Clutch Master CylinderPN 36700056B" is this a unit off the new touring models? On ebay I see it listed as PN 36700056 without the "B".
Old May 6, 2016 | 06:25 PM
DBLX's Avatar
DBLX
How hard was it? Video? What part of Ga are you in? I would like to do this mod as well on my 09.
Old May 6, 2016 | 07:03 PM
ssgunny's Avatar
ssgunny
If he responds cool. I have have not heard back from him concerning my last question. Hope he is enjoying his conversion.
Old May 7, 2016 | 05:20 AM
davidw221's Avatar
davidw221
What is the purpose of the Rushmore heavier springs with the Hydraulic clutch?
Old May 27, 2017 | 09:18 AM
HDnoob's Avatar
HDnoob
When doing the clutch switch, did you have to solder the new one in? I have a new switch but you can't access anything to remove the old one. I'm thinking that you have to cut and solder the new one in?
Old Jul 7, 2020 | 02:53 PM
GPGXP's Avatar
GPGXP
Hi There!
I have a 2012 Harley FLHTK that I have owned since new and planning on keeping the bike for sometime yet. I have been wanting to do the same conversion you did on your bike. Now that you have had some time with the hydraulic clutch, would you still recommend the upgrade? Rather an expensive upgrade for an 8 year old bike but like I said I plan on keeping it for a while yet. Looking forward to your comments!
GPGXP
Old Jul 8, 2020 | 03:11 AM
Keithhu's Avatar
Keithhu
Originally Posted by GPGXP
Hi There!
GPGXP
Well, 5 years after he posted this thread, and he only has 4 total posts. Good luck, and welcome to the forum!
