Air cleaner question
Old Aug 25, 2015 | 07:09 AM
bdtaylor1979's Avatar
bdtaylor1979
Originally Posted by leadman
Any problem with the front air scoop
sucking in water?
Haven't ridden in the rain yet, so not sure.
Old Sep 11, 2015 | 12:13 PM
OldPhat's Avatar
OldPhat
I have been rained on 3 times with my 2014 FLHX, the Rushmore air cleaner housing did
not suck in any water that I know of. I also have a K&N replacement air filter inside the
stock housing, K&N part HD-1614.
Old Sep 11, 2015 | 01:44 PM
todd-67's Avatar
todd-67
Even if is capablei think your throttle body cams and heads are tthe limiting factor after removing the backing plate with a stage 1 kit. Might be a good question for the engine section guys.
Old Sep 11, 2015 | 02:03 PM
batman.'s Avatar
batman.
I've ridden in more rain then I'd like to even think about. Even was riding out of Houston when tropical storm bill came rolling in. Sucked but the 14 air cleaner with a an big sucker backing plate never skipped a beat or sucked in water during my trip.
Batman
Old Sep 11, 2015 | 08:08 PM
smitty901's Avatar
smitty901
yes it will fit and you will not need a K&N filter the stock setup will flow all the air your engine can use unless you have done some major work to it.
As for rain I have ridden my 2016 in the rain already some pretty heavy rain the air cleaner is not an issue there either.
Old Sep 16, 2015 | 12:11 AM
leadman's Avatar
leadman
Thanks everybody.Still trying to decide
whether to make the change or not.
d24112
EVO
Jul 12, 2016 07:56 AM
gtrplyr
Feb 9, 2016 08:28 PM
dale44
Oct 6, 2013 03:17 PM
dblcruzin
Apr 14, 2009 11:54 AM
powerpro509
Apr 11, 2006 07:03 PM
