Eitms purpose
previous to EITMS cop bikes were using the parade fan, and many owners tried them as well-
what's better- blowing air over the fins to remove heat- or reducing the production of heat ( or maybe a little of both)
the first production motor ( I know of) to use this type of cooling strategy was the Cadillac Northstar. Caddy didn;t know how to explain this to the public, so in ads they just said that you could drive the car 50 miles with no coolant in it- yes, in that version the 8 cylinders alternated cooling air, so the car could be driven- not far, not fast, but driven.
Cadillac had experimented with cylinder de-activation in the early 80's ( the 8/6/4), by the late 80's and the Northstar, engineers realized that cylinder deactivation could also be used for cooling.
The prime use for this in cars is fuel economy.
car motors are primarily liquid cooled
eitms is a great advance and although not intended to cool the rider, less motor heat will mean less rider roasting
on my model you can disable the eitms by rolling the throttle forward and holding while at idle- the cruise control icon will turn red, do again and the icon will turn green: eitms on
living in Phoenix ( 108ş right now) I experience high temps on my bike- eitms will come on once in a while stopped in heavy traffic or what stopped at a long light when the bike has been ridden a while and it is hot.
I'm glad it's there.
On my evo I had a problem once at very high heat, I won;t ride the panhead in this.
Mike
Mike
from the 2014 Manual:
Mike
Even though the engine is designed to take the heat, why not enable it?
In addition to cooling the rear cylinder, it could keep the exhaust temp from rising while stopped and that is where you feel the heat. It might even save some fuel if you were in a lot of stop and go traffic.
Mike
Thats why its benefitial to go after the root cause which is excessive heat by installing Wards cooling fans (cools heads & upper cyls ) along with an ultracool oil cooler that has dual elec cooling fans that does a great job cooling the oil that collectively together reduced oil temp 50+ deg on my bike.
Benefits right off the bat when oil is running 50+ deg cooler in my bike's motor on a hot day are:
* MOTOR RETAINS MUCH BETTER / HIGHER OIL PRESSURE AT HOT IDLE & AT CRUISE TOO ALL TIMES.
* MOTOR DIDNT DETONATE ANYMORE ON HD'S REC 91 0CTANE FUEL.
* SAVED MONEY ON FUEL BECAUSE I DIDNT HAVE TO USE MORE EXPENSIVE 93 OCTANE FUEL ANYMORE . AND THE 93 FUEL ONLY REDUCED DETONATION BUT DIDNT FULLY STOP IT ON HOT DAYS UNDER LOAD BUT WITH THE OIL NOW RUNNING 50 DEG COOLER (HEADS & UPPER CYLS RUNNING COOLER TOO) THAT STOPPED THE DETONATION ALL TOGETHER EVEN WHEN RUNNING THE REC BY HD LOWER 91 OCTANE FUEL.
* VALVETRAIN REMAINS QUIET.
* LESS HEAT FROM MOTOR ONTO RIDER.
* MOTOR REMAINS MORE PWR/TRQ & CRISP THROTTLE RESPONSE EVEN ON ON HOTTER DAYS
SCOTT
