Mountain Riding Techniques
Last year for our HOG fall color run we shared the road with a car club that included Porches, Pantaras and a couple of Farraris. The only time they got ahead of us was on the straight aways. Maybe they weren't trying, but neither were we.
In the real world, which is what the OP was inquiring about, the bikes are always waiting on cars in the curves. You might want to address that issue instead of suggesting that cars could go faster if they wanted to.
Bill
Moving up to a newer bike with a factory sixth speed will work against you.
Example: My '06 is the last year of the five speed TC88's. The first gear ratio is 10.110. Fifth (final) gear ratio is 3.350.
A 2007 TC96 has a first gear ratio of 9.312, and a sixth (final) gear ratio of 2.790.
In 2009 (the OP's bike) the ratios were slightly lowered to 9.593 in first and 2.875 in sixth, where they remain, but note that the first gear is still geared higher than the TC88's five speed's first gear.
The newer bikes have steadily gained weight as well, which will work against you in slow speed manuevers.
And riding the friction point might be the correct method, but i personally don't like having the clutch in when i'm making a turn because the bike can fall over if it's not under power.
This is the method that motor officers use to negotiate parking lots like they do and still maintain control or whip a U-Turn within 2 lanes. Changing transmissions and other methods are not going to work. The bike will only go so slow before it falls over unless there is some power to the rear wheel to keep the gyro effect of the bike going.
Take the time and effort to learn this technique and you will no longer worry about a slow car on mountain road, or making a U-Turn on a 2 lane highway, or having to duck walk through a parking lot. Don't learn it and you will never be comfortable at slow speeds.
Bill
