What's wrong with her?
Old Sep 15, 2015 | 12:25 PM
mkguitar's Avatar
mkguitar
LOOK at the vacuum hose fitting before you change out the whole thing.
2 minutes vs an hour
Mike
Old Sep 15, 2015 | 06:33 PM
Dezz's Avatar
Dezz
Default Vacuum not the problem
Took off the hypercharger, put the stock intake back on with the vacuum cap, took it on a test ride, and still sputtering/missing/riding like chit.
Any other ideas before I take it in on Friday??
Old Sep 15, 2015 | 06:40 PM
batman.'s Avatar
batman.
Sounds like you got a vacuum leak somewhere.
Batman
Old Sep 15, 2015 | 06:42 PM
mkguitar's Avatar
mkguitar
yes check for a vacuum leak.
using a hose to your ear, move it around the intake manifold and listen for a rush of air or whistling.
any chance while the bike was sitting that someone backed a car into the aircleaner? I've seen that affect the intake seals
mike
Old Sep 15, 2015 | 06:49 PM
screamn_eagle's Avatar
screamn_eagle
gas doesn't go bad in 2 weeks....sounds like a vacuum issue as stated above. if you like the hyper thing then leave it on just check all your vacuum lines. popping at decal is a lean issue I am sure it has something to do with what you changed on the bike. actually sounds like too much air and not enough fuel....a tune may be in your future. do you have a fuel management system on the bike??? IE a race tuner or fuel moto pack or power commander or whatever?
Old Sep 15, 2015 | 07:22 PM
Dezz's Avatar
Dezz
Alright thanks for all the input guys, sounds like it might be a problem a little beyond my wrenching capabilities. I will be taking it in Friday and I will update with what the techs say. Thanks again fellas.
Old Sep 15, 2015 | 07:53 PM
dc3plt's Avatar
dc3plt
Fire it up, spray some carb cleaner around the intake manifold where it meets the head. If it changes the rpm at all, you've found your problem.
Old Sep 15, 2015 | 08:55 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
After "tinkering" on a bike and it starts to run chitty it is a good idea to revisit the "scene of the crime" just to see if you may have done something incorrectly.
If all looks well there, start looking elsewhere.
R U sure that your battery is fully charged and that both battery cables are clean and tight on both ends?
Bad fuel/water in the fuel is a possibility but since it was running good the last time you rode it seems an unlikely possibility, unless someone may have tampered with your bike.
As a last resort, a set of plugs couldn't hurt and they're not too expensive, before you take it to the shop.
Good luck.
Old Sep 16, 2015 | 01:34 PM
STA-BILŽ's Avatar
STA-BILŽ
Former Sponsor
Originally Posted by todd-67
Also might be bad gas. When is the last time you filled up and did you use a familiar station?
Originally Posted by Dezz
Haven't put gas in about two and half weeks. Won't hurt to fill her up with new gas, also I have Sta-bil's 360 that I haven't tried yet so maybe I will give that a go on the fill up.
It certainly could be bad gas. Today's ethanol blended gas can begin to break down in as little as 30 days. So if you filled up at a station with low turnover and then the bike sat for 14-17 days, you may notice a few performance issues. Go ahead and add STA-BILŽ 360°™ Powersports and see if that does the trick.
Please let us know if you have any fuel related questions.
Have a great day!
Old Sep 21, 2015 | 12:33 PM
mkguitar's Avatar
mkguitar
Dezz, how'd you end up on this?
find the problem?
Mike
