On a road trip, need some simple help
Old Sep 17, 2015 | 11:10 AM
sel53's Avatar
sel53
Default On a road trip, need some simple help
Guys, I have a quick question you might help with ...
2010 Road King, stock exhaust, the nut that holds the pipes by the catalytic converter to the bottom of the transmission ... It is loose.
What size deep socket do I need to get to tighten this thing?
Thanks
Old Sep 17, 2015 | 11:24 AM
oc1014's Avatar
oc1014
On my 2013 it's 14mm
Old Sep 17, 2015 | 11:35 AM
sel53's Avatar
sel53
Thanks!
Old Sep 17, 2015 | 11:52 AM
QNman's Avatar
QNman
9/16" on my 2010 (I think... may be 5/8", but pretty sure it's 9/16" - same as 14mm).
Old Sep 17, 2015 | 12:03 PM
sel53's Avatar
sel53
Yes, 14mm and9/16 sound like the same size.
Headed to Sears to get a travel ratchet & socket.
Thanks
Old Sep 17, 2015 | 12:17 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You're on a road trip and aren't carrying an ample tool kit with you? Wow dude! There are kits that will almost completely break down the entire bike that don't take up hardly any room at all. Better do some more shopping when you get back home!
Old Sep 17, 2015 | 12:39 PM
jaxdwg's Avatar
jaxdwg
Not to be funny, but a 14mm and a 9/16 are not the same. The 14 is a hair smaller and if you use a 9/16, you could round off the head, if it is very tight. Conversely, it can be tough to force a 14 onto a 9/16 bolt head.
Old Sep 17, 2015 | 01:20 PM
QNman's Avatar
QNman
Yeah, I know, but MOST of the sockets I've used are loose enough that they're interchangeable, and if you use a 6-point socket, it is VERY unlikely to round anything.
For the garage, I use only the correct sizes (2010 is still SAE, so 9/16"), but on the road, with no tools... either will do in a pinch to retighten a loose nut.
Old Sep 17, 2015 | 04:28 PM
jaxdwg's Avatar
jaxdwg
Yea, I know, but being an ASE master and an A&P, and used to build turbine engines, I'm a little **** about such things-- lol
Old Sep 17, 2015 | 06:11 PM
INJEKTER's Avatar
INJEKTER
the bracket about mid way with the carriage bolt? mines a 5/8
