electrical issue
Old Sep 18, 2015 | 05:47 PM
oldog54's Avatar
oldog54
2nd Gear
Default electrical issue
hope someone can help
problem is 07 st. glide runs fine i have all light but none of the gages work
speed od and tach not working
oil gage and volts not working
no neutral or any idiot lights on either
did all the fuse and checked all the grounds
was working went about 1 mile down the road and noticed at stop light
nothing working
thanks in advance for any info
wayne oldog54
Old Sep 18, 2015 | 07:00 PM
mkguitar's Avatar
mkguitar
everything you list uses the INSTRS 15 amp fuse.
if your fuse is good, then you'll have the trace the orange wire from the fuse box forward through the console interconnect then into the fairing
Old Sep 18, 2015 | 08:51 PM
Tactical111's Avatar
Tactical111
Replace the fuse just for the hell of it unless you used an Ohm meter on it and know for sure it's good. Check with volt meter to see if you have voltage on both sides of the fuse then go from there like MKGuitar says; follow that wire as it's probably pinched off somewhere.
Old Sep 20, 2015 | 05:06 AM
oldog54's Avatar
oldog54
2nd Gear
thanks for the replies
fuse blows as soon as the ignition is turned on.
goes to the shop friday
thanks again
oldog54
wayne
Old Sep 20, 2015 | 07:24 AM
rh8234's Avatar
rh8234
Have you done any work on the bike lately? Have you had switch housings off? If so, look for pinched wire in one of the housings.
Old Sep 20, 2015 | 11:05 AM
Vernal's Avatar
Vernal
nothing working
wayne oldog54
If i'm reading the schematic right that circuit also supplies the 12 v to the neutral switch. Might look for a short there.
blackxpress
Electrical/Lighting/Alarm
Jun 13, 2021 10:09 PM
Jswerve
Oct 8, 2018 08:06 AM
STLCHUCK
General Topics/Tech Tips
Jun 28, 2015 08:13 AM
Sharknose
Jun 5, 2007 06:28 PM
Hoopman
Apr 1, 2006 09:52 PM
