Just wanted to add next step up is not double the cost. For $276 you can upgrade from the emulsion shock to a separated. I have the S36e and love them but admit I still experience buyers remorse from time to time wondering if I should have invested the extra funds.
I guess you have to draw the line somewhere. I was looking for something that didn't constantly bottom out and handled better in the corners. The stock shocks wallow all over the place in aggressive turns. Of course I have really ridden these in aggressive corners yet but I know they will be better than stock. I think Harley can get away with their cheap air shocks in a 13" but shorting them to a 12 inch on the street glide just didn't work. At least not for me.
I may want to move up to that at some point but from what I can tell on the forum most if not all users of the basic shock I got seem to be very pleased with it's performance.
You should have bought what you eventually want now - buy once!
There is a feature of shocks which is routinely over-looked on HDF IMHO. If you ride mostly solo then many shocks are just fine, including your new Ohlins. If however you often ride 2-up then things change. Many shocks cannot handle the extra weight, also the passenger gets a quite different riding experience, compared with the rider. The separated shocks (which Mrs B and I have had for several years) give a much better controlled ride when we are fully loaded up. They are also very good solo of course!
We ride two up for 80% of the time. Will definitely step up next time around to the separated shock. Good point for those who are in the market for new shocks.
I will say that unless you ride in such a manner to over heat the shock so that the air oil emulsion separates you will never feel the difference between the two. Unless the stack is wrong but is close enough that it can be corrected by the clickers. Also keep in mind you lose shaft stroke when going separated as the divider piston takes up space in the body, about 3/4" . Unless your name is last name is on the back shoulders of your leathers, the emulsion style will do the job excellently, hardly an entry level shock in any way, shape, or form.
This is why I would upgrade if I had to do it again. Shocks do over heat when loaded up and riding all day. "unless you ride in such a manner to over heat the shock so that the air oil emulsion separates"
Emulsion is the type of construction all cheap and entry level shocks use and very few of them can be described as excellent. The 'air oil emulsion' is a consequence of all those things mixing together, which degrades damping performance. The separated variety keep gas and oil apart and prevent them from forming an emulsion, which is step up in performance.
Sir,currently I have Progressive 440 shocks on my '06 Ultra and I would like to upgrade to something better performing (Ohlins) but I'm a little confused.I was told that according to my (+ wife) weight I should get the #3s but when I look on the Ohlins site I see no #3s.Am I looking in the wrong place or they have different model nos.?I don't want an entry level shock nor the top-of-the-line but something that's reliable and works well.Any suggestion will be appreciated.Thanks
