I usually go for a good ride and oil gets up to operating temp of around 190.
Optimal temp is 180-220 to sufficiently evaporate the water from the oil. The lower the temp, the longer it will take and 190 is on the lower end of the scale. Water is a natural by-product of combustion. Next time you change oil, take it out for 100 mile ride, then drain it... Just be careful, it will be hot. Look at it then, shouldn't see any water.
The oil had around 3500 miles but was milky brown in color.
OK, that helps.
Few thoughts, none Harley specific.
It takes a surprisingly long time to get water out of oil. An afternoon ride/drive in fact many times won't get it all out. Especially if the oil never gets good and hot.
Condensation can bring a lot of water into the engine, particularly if the bike is stored in a dampish environment and goes through appreciable day/night temperature cycling. It will not usually be visible until you start and operate the engine, mixing the oil with the water that was on internal surfaces.
Water down an intake won't usually get much into the crankcase. The piston rings do a pretty good job of holding the water in the combustion chamber. But the water going up the crankcase vents, that can be appreciable. Especially if it's sprayed right into those vents.
just to protect the filter media- a plastic grocery bag over the air cleaner and the exhaust tips.
you can come back later with windex and clean those when the bike is dry.
possible you are not warming the motor enough to make up for the condensation formed in the cases when you do those short starts
( this can be a problem for the guys in the winter who start up the bike just to hear the pipes).
and in cold climates, water turns to ice and expands as it does...
Along with all the other suggestions like short rides not heating oil enough to drive moisture out could also be an issue with crankcase breather being clogged not allowing proper venting of moisture from crankcase too.
Bike is always warmed up before ride and yesterday I put on 250 miles before changing oil. Bike is stored in garage (partially heated) yearound.Breather is not blocked.I have it vented to ground behind trans, The bike is an 05 FLHTCEE with some engine inprovements.
UH, water doesn't boil off to a gas until 212*F, you need to ride it more and for crying out loud if youre going to douche your bike cover the inlets. As another fyi, water and oil and engine byproducts have sulphur in it, mixed with water it becomes acidic (as in sulphuric acid) which corrodes.
The water doesn't need to actually boil to evaporate but it does accumulate after shorter rides and it evaporates more slowly at lower temps. I'm guessing it's accumulated condensation. Spraying the air filter isn't going to get much water past the rings.
You'd pretty much have to stick the garden hose right straight into the throttle body to get water into the motor and crankcase.
