Winter Performance Upgrade
Old Sep 27, 2015 | 07:11 PM
bigskyroadglide's Avatar
bigskyroadglide
Default Winter Performance Upgrade
Looking for input to upgrade my stage 1 2010 RG 96 engine.
First, existing mods. Stage 1 basic HD open air cleaner and filter element. Vance and Hines Big Shot true dual, PC V with canned map. No oil cooler.
This setup yields about 42 mpg and is a dog down low but pulls great at 3k where I mostly ride. Sound at slow speed is loud, but at highway speed is tolerable and I can hear the radio at 75. Current set up does not run hot or go into EITMS.
I am aware the big shots are killing the low end, so part of the plan is either cutting the pipes off and adding slip ons or getting a de-catted 2-1-2 headpipe from an 11 model and slip ons
As to cams, wondering what people have had success with on the 96? Not looking to go bigger on engine size, already own a 120R, and a 107. Just looking for a little more umpth down low. Rarely turn past 4k, but tend to ride a 1000miles at a stretch. Mainly looking for easy start, super reliable torque cams.
Current thoughts Andrews 21, Woods 222, SE 255, or maybe one of the S&S easy start cams.
Got woods in all other bikes, but thought I might stray on this one...
Input?
Old Sep 27, 2015 | 07:20 PM
KSGLIDEGUY's Avatar
KSGLIDEGUY
I had the 222's in my 08 SG and they were awesome down low which is right where you are looking for more torque. A 2-1 exhaust combined with the cams would put a big smile on your face. That's my 2 cents.
Old Sep 27, 2015 | 07:32 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
without compression reales think i would have to look real hard at the easy starts. my 07 never liked to start when hot.
Old Sep 28, 2015 | 01:20 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Input?
Cams or no cams, you can get a 8-15% increase in your low and mid range power by putting some Thunder Torque Inserts into your Big Shots.
You'll probably like the deeper tone better also.
Here's a vid with a few bikes that have the TTI's in them.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Sep 28, 2015 | 06:31 AM
rsking45's Avatar
rsking45
I would leave everything the way it is and try the Andrews 48 cams. You might be happy with just a cam swap. These cams kicking around 2200 rpms and they just keep pulling
Old Sep 28, 2015 | 06:36 AM
just plain john's Avatar
just plain john
I run the 21's, pulls hard from right off idle to around 4500 or so.
Old Sep 28, 2015 | 08:43 AM
nhrider1's Avatar
nhrider1
Input?
Andrews 48's are definitely the way to go in a 96. Great torque and power increase across the range.
The Woods 222 has very similar specs and would probably be a strong runner also.
No need for easy start cams or compression releases on a stage-2 96. You will need to do something with those pipes.
Old Sep 28, 2015 | 08:51 AM
Uncle Larry's Avatar
Uncle Larry
No need for easy start cams or compression releases on a stage-2 96 ... There are a number of riders who have "hot start" problems with the SE-255's and I have a friend who is among them. Maybe the Andrews 48's are better. It's not the amount of "squeeze" so much as where it's "squeezed" at that makes the difference.
Old Sep 28, 2015 | 10:48 AM
Scudda's Avatar
Scudda
I just put these cams in my Fatboy over the winter and I absolutely love them!
Old Sep 28, 2015 | 01:47 PM
bklynbob's Avatar
bklynbob
+on the 48's......
desertwolf
Feb 22, 2015 12:52 PM
yzernie
May 5, 2013 05:56 PM
JDHunz
Sep 4, 2012 10:08 AM
ilovemyskidoo
Jun 22, 2012 12:45 AM
rosshog
Feb 3, 2012 02:24 PM
