Which cams or other engine mods should I do??? HELP!
I have recently purchased a Rush 2:1 full system exhaust to go on my stock 96" 2010 Road King w/ Stage 1 air cleaner. Here's a link to the exhaust, as many may not be familiar with it: http://www.epiflex.com/touringfullsystem.html.
My goal is to increase torque in the low and mid range as much as possible without breaking the bank. Not really looking to make it a top end drag racer. Just want some grunt from start and passing power. What are my options???
I've thought about just adding different cams, but wasn't sure which ones or if other engine mods should be done along with it to prevent damage. Should I fork over the extra dough and get the big bore stage II kit with new cams or just insatll different cams??? Any advice is greatly appreciated!
Stay with the 96" and put either a SE 255 or Andrews 48H Can in your bike and you will be Very Happy,,
Question do you have a Tachometer ??
So w/that in mind and seeing the course where these previous/similar threads have run I will say use the "Search" feature of this forum and say happy readin.'
Figure your build by how (and where) you ride. Ensure all future components are compatible.
What rpm range do you ride in? Where do you normally shift? Where do you shift when you're getting on it? Pay attention when you go out, you might be surprised at how much higher your rpms normally are vs what you would describe as your normal range.
Do you ride 2-up, spend a lot of time touring heavily loaded or pulling a trailer?
Are you a long mile rider, or spend more time doing short hops? Commute to work every day?
Is fuel mileage more important than performance, or vice versa? Do you care if your buddie beats you light to light, or down the onramp, or would you rather keep him in your rearview?
Do you want a showy idle? When you pull into the dealership, do you want the other riders to notice your bike for the way it sounds and idles, or would you rather they not notice you at all? (be honest). Does a little valvetrain noise bother you, or do you like the mechanical sound of your pushrod motor?
Are you planning future mods, like bigger pistons or ported heads?
Lots of things will shape how you build your motor. The more you know about how you ride and what you want, the higher your satisfaction is going to be with the results.
