Every vehicle on the planet with two or more cylinders has an exhaust that brings all the cylinders together in some way, which provides benefits in improved low/mid range torque. There is no other way of getting the same results. I swapped from TDs to my 2-into-1 and picked up a lot of torque in the rev range we mostly ride in, however the surprise is how much smoother running it is, a real bonus!
I voted 1, but i have the same set up and ditched the Rinehart extreme true duals for Dragos 2:1 and picked up almost 10 ft/lbs torque and moved it down where it's used. Sounds better to me too.
You're right. My credit card hates you.
Yep. I get it. My credit card hates you too.
I'll drop a D&D fat cat on the bike and see how it runs. If I need more after that we'll do the TW-777 and heads.
To follow up, I ordered the 107 with TW-999-6a cams, heads and the Jackpot 2:1 exhaust.
That should be a fun setup! Will be running the same in my bike but using the level C heads I believe. Just saw a bike run 120tq and 107hp with that cam and stock heads
To follow up, here is how the build turned out. Those of you that picked none of the above were correct. Glad I went that route, this build is really fun.
